Hi,
Not sure if I have this in the right forum or not. I apologize if I dont. My question is, If I play DVD in my laptop, is there a way or a program I can use to be able to save the movie to my hard drive or convert it into some type of form (AVI, MPEG, WMV, MOV, DIVX) where I can watch it on my work PC that does not have a DVD-ROM drive?
munchieman1019
Results 1 to 15 of 15
munchieman1019
Try FairUse Wizard. It converts to XVID fairly quickly and you should be able to burn the result to a CD. You will need a XVID player to view the video. I use Zoom player and VLC media player. VLC is the most versatile. All programs are freeware, though Zoom has a pay upgrade.
EDIT: Fairuse is free for 700MB size, bigger there's a small fee. But try it out. Zoom player needs the XVID codec to play, but VLC has it's own codec. -
How quickly is quickly? Itried to convert to DivX and I left the computer on for 6 hours and it wasnt done. I tried XVID and had the same result.
munchieman1019 -
It took me about 2 hours to convert my copy of 'Ice Age' to XVID using FairUse and burn onto a 700MB CD. Settings were mostly default. That seems fairly quick to me. And that's using a 1.9Ghz AMD CPU. And it's not fast.
The quality looks good and it plays perfectly on my laptop. CPU speed is the main factor for encoding time. Crunching down a DVD to the size that will fit on a CD and display decent quality takes a lot of computing power.
If your system is slower, let it run overnight. -
VLC can play the iso file directly, so there is no need to convert to a different format. Use DVDdecrypter (or DVDshrink if you want to remove some unwanted material) to rip the iso file to HD.
I was finally able to get it to work. It took about 2 1/2 hrs. (long but not bad). I usually do just use DVDDecrypter and watch the ISO image, but I wated to be able to let less "computer friendly" friends watch them too. Thanks to all of you for your help. Oh, its a 2.80ghz Pent. 4
munchieman1019 -
I like AutoGK to go to XviD, or you could convert to WMV either using Windows Movie Maker or Windows Media Encoder.
BTW, I *think* fair use only covers backups for your own personal use, not for giving to friends ...
If in doubt, Google it. -
I think you need to convert to an AVI first, then load that into Windows Movie Maker, because WMM does not like MPEG-2 files as source, judging by my own tests, as well as numerous googles ...
Is there a way to convert to M-PEG, AVI or WMV using Nero? I already have an ISO image of some movies. So I was wondering if I could conveert those. I'm using FairUse to convert something now and I was thinking I could use NEro to do some of the ISO images.
munchieman1019 -
So if I mount them on to my virtual drive can I then use Nero or another program to convert it like Fairuse?
munchieman1019
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
VHS Problem - LP possibly?
By Hackerpcs in forum Capturing and VCRReplies: 7Last Post: 4th Aug 2010, 09:03 -
Customized DVD (and possibly Blu-Ray) Menu Templates
By motown01 in forum Authoring (DVD)Replies: 1Last Post: 6th Oct 2009, 17:02 -
ghosting on ntsc dvd (possibly originally PAL)
By spiritgumm in forum EditingReplies: 5Last Post: 16th Jul 2009, 21:13 -
I'm looking for a HD DVD burner possibly with lightscribe
By tk001 in forum DVD & Blu-ray WritersReplies: 15Last Post: 31st May 2007, 16:34
