I'm using PPRO 1.0 and exporting with the Adobe MPEG Encoder to DVD compliant files (m2v and wav). Can anyone tell me how to select Closed GOPs? What is the default; open or closed? I have the MainConcept standalone encoder and can choose to use open or closed with it but cannot find the same choice in the Adobe MPEG Encoder.
Also, how can you tell if video has open or closed GOPs if you didn't encode it yourself.
I appreciate any help. Thank you.
.....Gord
Outside a dog a book is man's best friend. Inside a dog it's too dark to read.
------------ Groucho Marx -
This is a good question. Lately I have been exporting MPEG files from in my case Adobe Premiere Elements and was experimenting with variuos authoring programs. DVD-lab says that some of the exported files have open GOPs. Anyone have any ideas on how to fix this?
I'm not sure how to close all GOPs in Adobe's mpeg encoder, it may not have that feature. Really its not necessary and pointless to use unless you are encoding for multi-angle footage or possibly if you needed to do alot of post editing of the mpg. Closing GOPs lowers quality because your frames can only reference other frames within that same GOP.
The default setting in any mpeg encoder should be open gops, but gops will still be closed at scene changes.
If you want to check whether your file has open or closed GOPs you can use BitrateViewer. I know the full version shows this information and I think the trial version does too. Other than that you should assume your mpegs will have a mixture of open and closed gops.
Open GOPs are a good thing.
Premiere cs5 is crashing during the editing (is closed by someself)
By vladinar in forum EditingReplies: 2Last Post: 7th Feb 2011, 06:41 -
Premiere Pro Export setting?
By peconi in forum Authoring (Blu-ray)Replies: 12Last Post: 4th Nov 2008, 11:07 -
Closed GOP
By kitty in forum GlossaryReplies: 1Last Post: 13th Feb 2008, 00:14 -
Recommend a GOP setting for PAL-DVD/MPEG 2 files?
By Dark Alpha in forum EditingReplies: 1Last Post: 25th Jan 2008, 22:41 -
Glossery - Error in Closed GOP definition
By SCDVD in forum FeedbackReplies: 0Last Post: 8th May 2007, 19:08
