Hi. I was wondering if someone could recommend a good program that I could use to create menus? I am copying some home video to put on a DVD and would like to add a menu. Any info would be appreciated. Thanks.
dvd lab pro is the only one i would recomend.
i find ulead dvd software very "templatish"
at first it might look difficult but once you get the hang of it, you wont stop using it.I love it when a plan comes together! -
I use DVD Lab Pro and enjoy the freedom it has.
DVD Architect 3 is also pretty powerful, but you need to purchase Vegas 6 to get it
DVD Workshop 2 gets a good rap from the users here
Tmpgenc DVD Author is a great beginners package.
How complex do you wan't your menu to be ?
How much are you prepared to invest of yourself to create it ?Read my blog here.
Start with the free trial of DVD-lab. If you're still using it after 30 days then you'll agree that it's well worth the $99.
When you need more power you can upgrade to DVD-lab Studio or DVD-lab Pro.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Give TMPGEnc DVDAuthor a try, I really like it. I basically taught myself to use it by just reading stuff here. I have even begun inputing my own background images and whatnot, instead of just using the templates it comes with (very limited number of those, and personally I don't like them much). It's not hard, just give different ones a try and see what you like. I'm very happy with TDA so far, well worth what I paid for it.
My gear:
- JVC HR-S9911U SVHS VCR
- Datavideo TBC-1000
- JVC DR-M10 DVD writer
- Sony Steadyshot DCR-TRV340 NTSC Digital8 Camcorder -
Hi. I have been trying to use DVD-Lab Pro to create menus for some home video that I am transferring to a DVD, but I am running into a problem. After I compile my project and the program creates a VIDEO_TS folder it does not include a .IFO file and I cannot burn the DVD.
Can anyone suggest anything that might help.
creating a dvd menu
By petarone in forum Authoring (DVD)Replies: 2Last Post: 27th Dec 2010, 13:29 -
Recommendations for a DVD authoring program please
By psteel in forum Authoring (DVD)Replies: 12Last Post: 22nd Jul 2009, 18:27 -
Creating a DVD with Interactive Menu
By magus2008 in forum Authoring (DVD)Replies: 11Last Post: 20th Nov 2008, 07:33 -
Creating A DVD Menu
By 557953 in forum Authoring (DVD)Replies: 8Last Post: 19th Jun 2008, 09:41 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01
