Results 1 to 13 of 13
  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hello everyone, i was wondering how i can capture a screenshot of a certain point on a DVD film and save it on my comp. which proggie would i use, and will it let me SAVE AS a picture file with the same picture quality as my DVD? can i also go about this without having to encode the video? thanks
    Wow! You got shocks, pegs... LUCKY!
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    You can use Powerdvd, it has a small camera icon on the toolbar. Click and the image is saved. You can go into the preferences to choose the location of the file.
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    PowerDVD (camera icon) and windvd can do snapshots, pick the save location in setup. Same resolution.
    edit: bodyslide beat me to it!
  4. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    thanks guys, u rock! and now i assume i can print these pics rite...
    Nov 2002
    Delaware, USA
    Assuming you have a printer
    Veni Vidi Vici
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    This subject is covered in this sticky
    If in doubt, Google it.
  7. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    thanks very much
  8. Besides what mentioned , you can use Nero player or Photoshop Elements to do that ..etc
  9. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hey u joined on my birthday!! i tried using my PowerDVD, but its like version 5.0, and theres no camera icon, so ill try to get version 6.0 or higher, and ill also try NERO, thanks
  10. Member MrMoody's Avatar
    May 2002
    NTSC Land
    It's had it since v2 at least. My v4 has it.
  11. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok now for some reason, PowerDVD is being b!tchy with me, it doenst want to open, i click the shorcut, NOTHING. i go to the target and click that, NADA. i also looked a my NERO, and theres no camera icon or anything i can take a picture of the screen with. any ideas, thanks
  12. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You were born on 24 March 2005 ?
    You SUUUURE type well for a (presumably fat-fingered) 3 month old
  13. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    i couldnt stop laughin for a while...
    no im born on March 23, 1973. i just CELEBRATED my b-day... :P
