I have Alcohol 120% and can burn 1 BIN/CUE file into a CD-R, but how do I burn 2 on the same disk?
I also tried burning another BIN/CUE that is 812mb and it says there isn't enough space on the disk. Is there a way I can still burn this?
Originally Posted by shadowfox
I also tried burning another BIN/CUE that is 812mb and it says there isn't enough space on the disk. Is there a way I can still burn this?"Art is making something out of nothing and selling it." - Frank Zappa -
thanks for the reply ZippyP. I also wanted to know how to turn an AVI into a BIN/CUE file?
A bin/cue is just an image of a disk, many burning programs (nero?) can do that.
If what you really want is to turn your avi into a VCD/SVCD or DVD then you need to convert it into the correct format first, then burn it to disk (by creating a bin/cue if you wish). You might want to look for an "avi to whatever format" guide in the guides section under format conversion. Lots of step by step instructions there."Art is making something out of nothing and selling it." - Frank Zappa -
Well if the files were small enough (which in your case they are not), you could burn the bin/cue files as data onto your CD.
To read them, you would have to mount the images using Alcohol 120% or Daemon Tools for instance.
I ve saved multiple CD images onto DVD that way for instance - saves space compared to these pesky multiple CD applications. -
Just a side note, if your going to burn them to cdr...make SURE that your cd burner does in fact support overburn or else there's a fairly good chance that you will either end up with a bad burn, or POSSIBLY damaging the cd burner...or both.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 09:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
