I just got magic bullet suite and I can't get all the presets to work. How do I get my video to convert to 24p. Can someone give some step by step instructions. Thank you.
Results 1 to 11 of 11
what application are you using this with ?
anyway -- you do the 24 conversion ... MB is for looks
Im surprised you spent 500$ without not realizing this ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
DV Film Maker does an excellent 60i to 24p conversion, plus some film effects. It's only $149. and a standalone program.
www.dvfilm.comYour miserable life is not worth the reversal of a Custer decision. -
Originally Posted by Koleman
Hope you have a render a farm, or at least a good DuOp or Xeon workstation setup. MB can take DAYS to render an hours worth of footage. Depending on of course what other effects you have on the time line.
Save yourself time and money, and get a true progressive cam to shoot with. The quality will be much higher than a software render. Then use a simple add grain, or film-look filter, to add the desired effect. Vegas and Premier have some built in examples to help guide to certain "film looks".
Magic Bullet is a great plug in, but I can't think of why a home user would want to put him/herself through that much punishment
11.5 hours for 2 minutes 20 seconds of footage from film looks and vegas 5. Careful use of primary and secondary colour correction and a good levels filter can mimic most of the 'Looks' filters in MB. Big Film FX can also produce pretty good results much faster, including letterboxing, and cinelook is also worth a look-see.
Read my blog here.
Originally Posted by guns1inger
you can also use Celluloid for Vegas, which renders 10x faster than MB and does pretty well the same effects. It also has all the 24p conversions set up .
MB IS extremely slow.
http://www.vasst.com/product.aspx?id=86a3c0d0-67d6-4e7b-8219-d80848cbd5ca"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I wonder how much time some newbies will still need for discovering that
MS Paint can save as .GIF, .JPG and .PNG too.
24p source to 24p DVD - am I doing it right?
By Killer3737 in forum Video ConversionReplies: 30Last Post: 14th Oct 2011, 18:40 -
Anyone using Magic Bullet Looks Suite 1.1 to 2.1?
By cooldude859 in forum EditingReplies: 0Last Post: 7th Jan 2010, 04:31 -
AVCHD conversion to 24p
By kippard in forum Video ConversionReplies: 5Last Post: 31st Aug 2009, 02:27 -
24p -> pal -> ntsc back to 24p
By StrobeLightEpileptic in forum Video ConversionReplies: 1Last Post: 14th Aug 2009, 00:56 -
Troubles with 16:9 and Magic Bullet in Compressor
By ehmjay in forum MacReplies: 1Last Post: 30th Mar 2008, 15:46
