how do i watch a short sample of a movie,using only a few rars???
Results 1 to 9 of 9
in a couple words, you can't. extracting RARs required that they all be present.
I'd like to be able to do that as well, sadly.TANSTAAFL -
please use the search. first hit for rar:
https://www.videohelp.com/forum/viewtopic.php?t=272195&highlight=rar -
You can try the following:
Get some of the first RAR archives from the set.
When extracting enable the option "Keep broken archives"
You can extract the RAR archives now and when there are no more available you can cancel and keep the partially extracted file.
Most partially movie files you then can playback with a good player like Mediaplayer Classic or AVIPreview.
Ofcourse when there's only a disk image inside things get more complicated. 8) -
i think i know what "movies" you're talking about.. most of them use no compression when rar'd, because they're already highly compressed, so using rar compression would pretty much be useless.. but what is useful is to rename one of the rars with an .mpg extension and view through your desired movie player..
if the movie is actually compressed using rar compression then u won't be able to simply play the rar file (or some files from a set) in windows media player.
if its just an uncompressed file packaged in a rar archive then u can play it in a variety of different players, although some are more tolerant of errors than others. it will most probably be like this if it is a movie file as WinRAR automatically won't compress some file types like MPG, ZIP, and RAR when it adds them to archives.
Editing movie like those that we watch on tv
By jare3094 in forum EditingReplies: 2Last Post: 13th Dec 2010, 16:09 -
Software to make sample of movie
By cyberlion in forum EditingReplies: 5Last Post: 7th Aug 2010, 07:32 -
How to watch a movie?
By shapper in forum Newbie / General discussionsReplies: 3Last Post: 15th Jul 2008, 21:59 -
The size of those RARs and PARs + ??
By rotuts in forum MacReplies: 3Last Post: 13th May 2008, 12:46 -
Are you going to go watch the TRANSFORMERS movie?
By yoda313 in forum PollsReplies: 24Last Post: 7th Jul 2007, 09:52
