I have a strange request. I need to find a new DVD player for my church. I need to be able to disable the on screen display (so that, for instance, when I hit pause it doesn't show pause on screen). This unit will also double as a CD player and I need something that won't skip/pause in between tracks. We play lots of cd's that have one song split into many tracks, and if the player puts a gap in between then we have a problem. Many cheaper units i've used had this problem. The Sony player we currently have works fine though.
Reliable CD-R, DVD-R and DVD+RW playback is required.
Any suggestions? These aren't specs they normally list...
zach
You may want to take a disc with you up to the store and try them out for yourself. All of the players that I have used, display the commands on the screen, but there could be a menu option to disable that.
Google is your Friend -
Your computer does that already does it?? Control it with the mouse.
kiki -
What does his computer and mouse have to do with anything? He asked about a standalone player.
VLC : OSD time changing from hh:mm:ss/hh:mm:ss to hh:mm:ss.xxx/hh:mm:ss
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 18th Nov 2011, 08:20 -
Neuros OSD or Something Like It?
By justapilgrim in forum Capturing and VCRReplies: 7Last Post: 28th Feb 2011, 20:36 -
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 02:00 -
osd/coverart
By Marccc in forum Newbie / General discussionsReplies: 0Last Post: 30th Sep 2010, 07:24 -
PowerDVD - using OSD panel?
By terrypin in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2008, 04:12
