Converting DivX clips of 43 minutes using MP3 audio converted to 256k WAV. I'm trying to fit at least 6 clips on a single DVD. I did it before, so I know for sure it can be done. For some reason, I can't seem to make the size change anymore.
Compressed in 4 different ways:
352x480, 23fps, CBR 2000 = 733,913 bytes
720x480, 29fps, CBR 2000 = 733,919 bytes
720x480, 29fps, CQ 80 = 733,899 bytes
720x480, 29fps, CQ 90 = 733,899 bytes
For CQ-80 and CQ-90 being 100% identical, I have a feeling TMPGEnc is completely ignoring my settings.
Results 1 to 11 of 11
Let me guess . . . Did you have to re-install TMPGenc recently, and you've forgotten to load the unlock templates?
I've been down that road a few times myself, I know what it feels like!
Try to load the unlock templates from the project window, it may give you finer control over your settings . . ."I've got a present for ya!" - TTWC -
Nah, I can modify the settings by clicking on the label and selecting "Unlock". Besides, CQ percentage is never locked.
Nope. 2.56.39.143Originally Posted by bugster
Nope. "MPEG-2 Program (VBR)"Originally Posted by Abond
I'm sure the problem is something stupid. I would say the bit rate is too great, but I can't get it lower than 2000. I don't see how a bit rate of 10 would give a 800mb file, but whenever I try to enter something less than 2000, it brings back 2000 automatically. -
It's no surprise that those two are practically identical - the only factors that influence filesize are running time and bitrate, and since both are identical, you would expect the file size to be identical alsoOriginally Posted by Lyverbe
I'm sure someone else had this problem quite some time ago here ... can you post screenshots of the CQ settings (press the settings button next to where you set the Rate Control Mode to CQ) - this sticky might help you with the screenshots - for both the CQ 80 and CQ 90 so we can see if we can pick up anything amiss ?Originally Posted by Lyverbe
EDIT:
That sounds to me like you're using the wizard ?Originally Posted by LyverbeIf in doubt, Google it. -
Got it!
Even though I was trying to enter something less than 2000 bytes, TMPGEnc would revert it back to 2000. I was able to change that value after loading the unlock.mcf file. I thought this file was only to enable the disabled controls, like doing every "Unlock" instead of having us doing them one by one. Apparently it does more. I should have listened to Tao
So, I changed the bitrate to 1800 and was able to put 4.5 hours of clips on my DVD.
Still, thanks for all your help and input. It's appreciated. -
Congrats Lyverbe! Glad to see you got that sorted out!Originally Posted by Lyverbe
Trust me, I've been down that same road a few times myself!
Cheers!
TTWC"I've got a present for ya!" - TTWC
VirtualDubMod ignoring my target size on XVID files
By tat2jr in forum Video ConversionReplies: 20Last Post: 12th Oct 2013, 18:10 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:14 -
mencoder AVI: invalid audio stream ID: 128 - ignoring (nosound)
By dialallama in forum Video ConversionReplies: 3Last Post: 4th Mar 2009, 08:17 -
Dvd Author Ignoring jump chapter n in title pre commands (no errors)
By FallenAngel10 in forum Authoring (DVD)Replies: 0Last Post: 7th Jul 2007, 16:04 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 11:52
