Hi there,
For one of my classes, I have an instructional DVD, which has unfortunately passed through so many hands, that it has become scratched beyond repair.
I was able to extract part of it on my computer, after a lot of trial and error, and I ended up with a number of .VOB files which I'd like to author into a new DVD. Luckily, they're exactly what I needed; there was more on the original disc, but I can't get to those at all... I need a simple "translation" of these .Vob files into a format which can be used by Ulead to make a new DVD, with a simple menu.
The guide posted here https://www.videohelp.com/forum/viewtopic.php?t=224833
is terribly complicated...
Does anyone know of a program/utility that would do this conversion?
Note: I can't use DVDShrink or lots of other programs, since the ripping was incomplete.
Womble MPEG Video Wizard can do the job. It's a bit expensive, but it has a 30 day free trial. It's a sweet program!
Good luck!
(Hi Yoda) -
Load the VOBs into Womble Mpeg Video Wizard and save as mpg.
Download the time limited evaluation.
Uhh, I was a little bit behind previous poster -
vob2mpg will do the job:
https://www.videohelp.com/forum/viewtopic.php?t=252033
If you need to recalculate the pts b4 you author then see this too: https://www.videohelp.com/forum/viewtopic.php?p=1237140#1237140SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
LOL, I figured it out... it was simply a question of renaming all the .VOB files I needed to .MPG... Ulead did a great job in making a DVD with them, and there's no A/V sync issues I'm aware of...
Thanks everybody, I'm looking into the programs you suggested anyway, you never know when I'll need them...
Cheers! -
That won't always work right. Baldrick's solution is the cleanest and easiest way to do this right.Originally Posted by AnitaPeterson"Rarely is the question asked: Is our children learning?"
George W Bush - Moron
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 15:39 -
Simple VOB authoring solutions
By kippard in forum Authoring (DVD)Replies: 5Last Post: 22nd Jul 2008, 08:27 -
Frustrated and Lost ! All I need is a simple menu for VOB files
By vulcan_man in forum Authoring (DVD)Replies: 7Last Post: 26th Feb 2008, 05:12 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45
