Hi, everybody,![]()
Does anyone know a fast and easy way to convert subtitles in SUP format to PNG files which spumux can understand. I also need a text file in srt format.
I know spumux takes text subs but I want to use SubtitleCreator to produce SUPs because SubtitleCreator flexible functions to set the font style like 'bold', 'italic', etc.
I tried rather a complicated method like this:
1) Made a SUP and a text file with frame numbers, using SubtitleCreator.
2) Converted the SUP to BMPs using DVDSupDecoder.
"C:\Program Files\DVDSupTools\DVDSupDecode.exe" -bitmap -ntsc test.sup
3) Converted the BMPs to PNGs using GraphicsMagick.
4) Converted the text file to SRT with subtitle timings. I used SubtitleWorkshop to do this.
5) Created configuration xmls for DVDAuhtor and spumux.
6) Authored a new DVD in DVDAuthor.
I played the new DVD. It's perfect, except one problem: the subtitle colors.
I had forgotten to adjust the colors!!
Does anyone know of a better way or a tool which can do the whole process?
Any help will be appreciated!!
I don't know if this question is still open?
The required tool is either pxsup2dast (included in dvdauthorgui, or compile it yourself: http://www.guru-group.fi/~too/sw/m2vmp2cut/pxsup2dast.c )
or sup2png included in GUI for dvdauthor (or download seperatly here:
https://www.videohelp.com/~gfd/edcounter.php?file=download/sup2png_src.zip )
I tried to make sup2png a little bit more stable than pxsup2dast and also support all 16 possible palette colors with variable transparency.GUI for dvdauthor:
Spumux problem
By Bigfoot73 in forum Authoring (DVD)Replies: 0Last Post: 15th Sep 2010, 15:08 -
spumux.exe
By ranee in forum Authoring (DVD)Replies: 3Last Post: 30th Jun 2010, 09:31 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21
