I frequently burn AVI's to VCD's but I almost always get sync problems. I usually do it through the VCD encoder in toast and this is usually how I get the problems. I don't have problem with bin/cue files though. What is the best way, for example, to go from a AVI with AC3 audio to a burned VCD? Thanks for all the help! If it helps, I'm running Tiger with a 1.25ghz G4 and 768MB of RAM. Thanks again!
The Rules of Mac apply Here:
Q.R.E.A.M.
( Quicktime Rules Everything on A Mac)
Toast uses QT to encode to MPEG-1.
QT has to like the flavor of the .avi,
and almost with out fail has issues
with DIVX flavored avis.
What I've done in the past was to get
the AVI's over to a QT .mov file, either through
using Divx Doctor II ( which is kinda obsolete now)
or by using ffmpegx.
If you use ffmpegx, you can also re-encode the audio
at the same time to generic AIFF or MPEG audio, which will
help in the muxing to MPEG-1 in Toast. -
Which was why I was saying its kinda obsolete now....
yes, the ffmpegx settings should work."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 01:40 -
avi to vcd
By cornick in forum Video ConversionReplies: 4Last Post: 11th Aug 2008, 21:12 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 07:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
