  1. hi ! I have a prob using this tool. I have my videos and Im ready to burn but the program ask for a temp folder where to put the files, the thing is that I dont have enough space. Is there a way so the program does not use a folder ?
    Thanks!
    Apr 2003
    Maryland
    You need a place to temporarily store the file recode prepares. I'm not sure if it can be done on the fly with no temp. I would not trust that anyway.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
  3. Any program needs some working room and temp folder to do its work, Nero scans and remembers the changes so it can do high quality encode. If you don't have enough space your window when it wants to page to disk may crash and then you will loose everything. If you are playing with video or working with it you need to add a new hard drive, in these days a 120 gigs is not that expensive.
