i have about 50 saturday night live clips i want to put on dvd but some have higher volume than others. how can i encode these vids and noralize the audio and batch encode (way too many clips to normalize individually
thx!
Basically, any normalizer works with WAV audio, the exception (AFAIK) being MP3Gain, which works with MP3 without decompressing to WAV first. So, depending on your source files, you do have to extract the audio. If it's MP3 audio, you can use MP3gain on those, for all other formats, you have to decode to wav, the normalize.
Look for some CLI apps to perform the needed steps, write a .BAT script for them to automate the process.
What to look for, depends on in what format your source files are, but the steps (worst case) are:- Extract audio
Decode to WAV
Normalize
Encode to ???
Multiplex back with video
/Mats - Extract audio
AutoMKV hangs with message "first normalizing volume - WAIT" message :(
By Jackie78 in forum Video ConversionReplies: 1Last Post: 25th Dec 2011, 05:33 -
questions about audio normalizing and audio encoding
By codemaster in forum DVD RippingReplies: 2Last Post: 25th Sep 2011, 21:22 -
Adjusting audio volume in batch
By SearchQuality in forum AudioReplies: 7Last Post: 20th Jan 2011, 03:16 -
batch volume raise?
By m-man in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jul 2008, 00:53 -
Volume normalizing
By grandsire02 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 11:01
