Hi
I have an xvid movie file which plays fine on my PC using PowerDvd.
When I convert it to DVD using the latest version of Svcd2dvd the sound is way out of sync with the lip movement.
The mpeg file made when converting also has audio out of sync when played on the PC.
I have other xvid files which have been converted ok so I suspect the file is corrupt but I am puzzled that it plays ok before convertion and DivFix does not fix it/show any errors.
This is the log file from my problem convertion:
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Name: SVCD2DVD 2.0 RC9b
Title: 2.0 RC9b
Version: 2.0.1961.16804
Executable: C:\Program Files\BadgerSoft\SVCD2DVD 2 BETA\SVCD2DVD.exe
Executable size: 2.27 MB
Executable size in bytes: 2383955
Executable CreationTime: 15/05/2005 09:22:02
Executable LastWriteTime: 25/06/2005 00:11:26
Executable LastAccessTime: 28/06/2005 19:53:33
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 1
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 990 MB
Free Physical Memory: 655 MB
Total Virtual Memory: 2.33 GB
Free Virtual Memory: 1.79 GB
***************************** Computer *****************************
Computer Manufacturer Name:
Computer Model:
System Type: X86-based PC
Computer Name:
DomainRole:
Number Of Processors:
User Name:
***************************** Processor ****************************
Manufacturer: GenuineIntel
Processor: Intel(R) Pentium(R) 4 CPU 3.20GHz
Description: x86 Family 15 Model 3 Stepping 4
CPU Speed: 3.192GHz
CPU FSB: 200MHz
L2 Cache Size: 0 bytes
CPU Speed: 3.192GHz
CPU FSB: 200MHz
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: ATI RADEON 9100 PRO IGP Series
Processor: RADEON 9100 XT IGP AGP (0x7834)
Mode: 1280 x 1024 x 4294967296 colors
Video Ram: 32.0 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 6.20 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 131 GB
********************* END OF SYSTEM INFORMATION ********************
Processing assets for DVD creation
AVI2MPG: 5752kbs Full-D1
Pass 1/1: Processing lrc-lc-dvdrip.avi
21:38:33: ffmpeg version 0.4.9-pre1, build 4754, Copyright (c) 2000-2004 Fabrice Bellard
21:38:33: configuration: --disable-debug --enable-a52 --enable-gpl --enable-memalign-hack
21:38:33: built on May 5 2005 19:13:42, gcc: 3.2.3 (mingw special 20030504-1)
21:38:33: Input #0, avi, from 'D:\Movie Archive\LC.DVDRIP.xVID-LRC\lrc-lc-dvdrip.avi':
21:38:33: Duration: 01:41:05.4, start: 0.000000, bitrate: 970 kb/s
21:38:33: Stream #0.0: Video: mpeg4, yuv420p, 576x240, 25.00 fps
21:38:33: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 126 kb/s
21:38:33: Output #0, dvd, to 'D:\Movie Archive\LC.DVDRIP.xVID-LRC\lrc-lc-dvdrip_S2D.mpg':
21:38:33: Stream #0.0: Video: mpeg2video (hq), yuv420p, 720x576, 25.00 fps, q=1-31, 5752 kb/s
21:38:33: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
21:38:33: Stream mapping:
21:38:33: Stream #0.0 -> #0.0
21:38:33: Stream #0.1 -> #0.1
22:51:03: video:3676488kB audio:165702kB global headers:0kB muxing overhead 2.020038%
22:51:03: AVI2MPG: done.
22:51:03: Done: Processing assets for DVD creation
Authoring DVD Folders
22:51:03: Creating TitleSet # 1
22:51:03: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
22:51:03: -->: DVDFolders creating VTS
22:51:03: -->: VTS 01
22:51:03:
DVD Folders: Processing D:\Movie Archive\LC.DVDRIP.xVID-LRC\lrc-lc-dvdrip_S2D.mpg...
22:55:14:
22:57:00:
22:57:00: Finalising DVD...
22:57:00: SVCD2DVD: DVDfolders
22:57:00: -->: DVDFolders creating table of contents
22:57:00: scanning D:\Dvd Images\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
22:57:00: Finalising DVD...Done
22:57:00: Done: Authoring DVD Folders
Any ideas?
mesaboogieman
Results 1 to 14 of 14
No.Any ideas?
But i have seen this once myself a while back. Can you upload the file to my ftp so i can investigate?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks I will investigate.
Hi again ChrissyBoy
Forgot to mention that I have converted this file to DVD using Nero and the sound sync is ok when played on PC or stand alone DVD player, so it appears the file is ok?
mesaboogieman -
Ok. Got it. Ironically i am waiting on new speakers from eBay arriving. My old ones got fried... Should be here tomorrow.
Hi ChrissyBoy
Did you have the same problem with the sound as I did?
mesaboogieman -
Yes i did find this to be the case. I am looking into it. It would seem that there is a lot of "JUNK CHUNKS" at the begining...
No not yet. I have tried many things/tools to identify, fixed the issue. Whatever i use actually creates the same sync issue in the avi that we see in the mpeg! I have sent a sample to the ffmpeg development team to investigate too, so we can but wait I'm afraid.
Ok i have a solution for you. Using AVI-Mux GUI
Fireup AVI-Mux GUI:
Add your file to the list:
1. Then Click on the file.
2. Click on "Generate data source...."
3. Click on the Audio stream
4. Note the Audio delay. This is the issue we have!
5. Click "Start".
A new file will be saved with the audio delay resolved. Process as normal in SVCD2DVD!
The AVI-Mux GUI process takes under 2 minutes for a 700MB AVI file.
Let me know how you get on.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hi ChriisyBoy
Tried your 'fix' and it worked a treat, sound now in sync after converting to Dvd with Svcd2Dvd.
Noted that the 'fixed' file generated from AVI-Mux did not play on my PC with PowerDvd or WMP although the original did, but after converting with Svcd2Dvd all is ok.
Many thanks for your help.
mesaboogieman -
No problem. It should play in MPC.
Xvid Sync Problem
By Peru in forum AudioReplies: 4Last Post: 21st Feb 2011, 14:15 -
Sound out of Sync in conversion
By opala in forum Video ConversionReplies: 2Last Post: 17th Apr 2009, 20:15 -
XviD avi out of sync
By Silenceville in forum Video ConversionReplies: 17Last Post: 17th Feb 2009, 11:12 -
Help with conversion to Xvid
By zovx in forum DVD RippingReplies: 2Last Post: 6th Feb 2008, 16:32 -
riverpast rm to avi conversion sound out of sync
By princevegetam in forum Video ConversionReplies: 9Last Post: 2nd Jul 2007, 03:45
