Results 1 to 9 of 9
    May 2005
    Houston,TX
    I am keep on getting this SVCD2DVD error message that force me to send an error message to Microsoft and then close out the svcd2dvd. I was told to re-install the software and I did but it didn't help.
    This software worked with 2 or 3 mpg files but when I try it with the AVI for more than 6 mpg files then it corrupted.
    Please help.
    Here my error -
    Version:SVCD2DVD 2.0 RC9b
    Type: System.NullReferenceException
    Source: SVCD2DVD
    Message: Object reference not set to an instance of an object.
    InnerException:
    StackTrace: at
    x3284ccece41ee22b.xd3764d4f1e921081.x3b9d134dac76e 484(xece14591aa1abb99 x50afe96f7df19242, xcbd1127f90d7945f
    x3146d638ec378671)
    at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
    at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
    DeleteReplyForwardSpamMove...
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Can i see the log file for this run please?
    May 2005
    Houston,TX
    I will post the log file when I get home tonight.
    Thank.
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    ok thanks.
    May 2005
    Houston,TX
    Ok, here is my error log files... I ran it again just to make sure the error is still existed.
    The windows error message is "ffmpeg.exe encountered a problem and needs to close". The 3rd times I get this, it shut my computer down completely.
    Any help is greatly appreaciated.
    Error log file..
    ************************ SYSTEM INFORMATION ************************
    ***************************** SVCD2DVD *****************************
    Name: SVCD2DVD 2.0 RC9b
    Title: 2.0 RC9b
    Version: 2.0.1961.16804
    Executable: C:\Program Files\BadgerSoft\SVCD2DVD 2 BETA\SVCD2DVD.exe
    Executable size: 2.27 MB
    Executable size in bytes: 2383955
    Executable CreationTime: 5/15/2005 3:22:02 PM
    Executable LastWriteTime: 5/28/2005 4:04:11 AM
    Executable LastAccessTime: 6/28/2005 9:58:25 PM
    ************************* Operating System *************************
    Operating System: Microsoft Windows XP Professional
    Service Pack: Service Pack 2
    Version : 5.1.2600
    Windows Directory : C:\WINDOWS
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 1
    Local: 0409
    Total Physical Memory: 0.99 GB
    Free Physical Memory: 654 MB
    Total Virtual Memory: 1.99 GB
    Free Virtual Memory: 1.96 GB
    ***************************** Computer *****************************
    Computer Manufacturer Name: PT880_
    Computer Model: AWRDACPI
    System Type: X86-based PC
    Computer Name: PT-VT7ABIT
    DomainRole: x2c3419cdc9b8e007
    Number Of Processors: 2
    User Name: PT-VT7ABIT\danh
    ***************************** Processor ****************************
    Manufacturer: GenuineIntel
    Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz
    Description: x86 Family 15 Model 3 Stepping 4
    CPU Speed: 3.014GHz
    CPU FSB: 200MHz
    L2 Cache Size: 0 bytes
    CPU Speed: 3.014GHz
    CPU FSB: 200MHz
    ***************************** Time Zone ****************************
    Time Zone: (GMT-06:00) Central Time (US & Canada)
    ****************************** VIDEO *******************************
    Name: RADEON 9200 SERIES
    Processor: RADEON 9200 SE AGP (0x5964)
    Mode: 1024 x 768 x 4294967296 colors
    Video Ram: 128 MB
    Status: OK
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 120 GB
    DeviceID: E:
    FileSystem: NTFS
    FreeSpace: 281 GB
    DeviceID: F:
    FileSystem: NTFS
    FreeSpace: 37.2 GB
    ********************* END OF SYSTEM INFORMATION ********************
    Processing assets for DVD creation
    Processing Huyet Chien Tinh Thu 01.mpg
    17:04:23: Converting PAL to NTSC (VCD Profile)
    17:04:24: ffmpeg version 0.4.9-pre1, build 4754, Copyright (c) 2000-2004 Fabrice Bellard
    17:04:24: configuration: --disable-debug --enable-a52 --enable-gpl --enable-memalign-hack
    17:04:24: built on May 5 2005 19:13:42, gcc: 3.2.3 (mingw special 20030504-1)
    17:04:24: Input #0, mpeg, from 'E:\Movies\Huyet Chien Tinh Thu\Huyet Chien Tinh Thu 01.mpg':
    17:04:24: Duration: 00:43:28.1, start: 0.239467, bitrate: 1294 kb/s
    17:04:24: Stream #0.0: Video: mpeg1video, yuv420p, 352x288, 25.00 fps, 1150 kb/s
    17:04:24: Output #0, dvd, to 'E:\Movies\Huyet Chien Tinh Thu\Huyet Chien Tinh Thu 01_S2D.mpg':
    17:04:24: Stream #0.0: Video: mpeg2video (hq), yuv420p, 352x240, 29.97 fps, q=1-31, 1250 kb/s
    17:04:24: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
    17:04:24: Stream mapping:
    17:04:24: Stream #0.0 -> #0.0
    17:04:24: Stream #0.1 -> #0.1
    Merging TitleSet #1
    skipping - single Title
    Processing Huyet Chien Tinh Thu 02.mpg
    17:15:13: Converting PAL to NTSC (VCD Profile)
    17:15:14: ffmpeg version 0.4.9-pre1, build 4754, Copyright (c) 2000-2004 Fabrice Bellard
    17:15:14: configuration: --disable-debug --enable-a52 --enable-gpl --enable-memalign-hack
    17:15:14: built on May 5 2005 19:13:42, gcc: 3.2.3 (mingw special 20030504-1)
    17:15:14: Input #0, mpeg, from 'E:\Movies\Huyet Chien Tinh Thu\Huyet Chien Tinh Thu 02.mpg':
    17:15:14: Duration: 00:42:13.0, start: 0.411611, bitrate: 1294 kb/s
    17:15:14: Stream #0.0: Video: mpeg1video, yuv420p, 352x288, 25.00 fps, 1150 kb/s
    17:15:14: Output #0, dvd, to 'E:\Movies\Huyet Chien Tinh Thu\Huyet Chien Tinh Thu 02_S2D.mpg':
    17:15:14: Stream #0.0: Video: mpeg2video (hq), yuv420p, 352x240, 29.97 fps, q=1-31, 1250 kb/s
    17:15:14: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
    17:15:14: Stream mapping:
    17:15:14: Stream #0.0 -> #0.0
    17:15:14: Stream #0.1 -> #0.1
    Merging TitleSet #2
    Processing Huyet Chien Tinh Thu 03.mpg
    17:48:08: Converting PAL to NTSC (VCD Profile)
    17:48:09: ffmpeg version 0.4.9-pre1, build 4754, Copyright (c) 2000-2004 Fabrice Bellard
    17:48:09: configuration: --disable-debug --enable-a52 --enable-gpl --enable-memalign-hack
    17:48:09: built on May 5 2005 19:13:42, gcc: 3.2.3 (mingw special 20030504-1)
    17:48:09: Input #0, mpeg, from 'E:\Movies\Huyet Chien Tinh Thu\Huyet Chien Tinh Thu 03.mpg':
    17:48:09: Duration: 00:42:23.8, start: 0.287767, bitrate: 1294 kb/s
    17:48:09: Stream #0.0: Video: mpeg1video, yuv420p, 352x288, 25.00 fps, 1150 kb/s
    17:48:09: Output #0, dvd, to 'E:\Movies\Huyet Chien Tinh Thu\Huyet Chien Tinh Thu 03_S2D.mpg':
    17:48:09: Stream #0.0: Video: mpeg2video (hq), yuv420p, 352x240, 29.97 fps, q=1-31, 1250 kb/s
    17:48:09: Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
    17:48:09: Stream mapping:
    17:48:09: Stream #0.0 -> #0.0
    17:48:09: Stream #0.1 -> #0.1
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    May 2005
    Houston,TX
    Well, i did pull my cpu and fan out before (thinking that the cpu is getting hot) but that didn't help. I also have the same problem on another machine. Anyway, I will try it again and see what happen.
    any other suggestion.
    May 2005
    Houston,TX
    well, I cleaned my cpu and fan out but it still the same. The CPU run at 40 degC (normal) and increased to 55 when running SVCD2DVD. It keep on flaging me about the ffmpeg file.
    frustrated, but still looking for help.
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    ok it looks from the log that 'Huyet Chien Tinh Thu 03.mpg' fails. Can you try that mpg on its own to see if you still get the crash? Then maybe you could upload it to my ftp to see if i can replicate this?
