Is there any MPG2 Encoder that can import a chapter list?
Results 1 to 15 of 15
What for? How do you mean?
/Mats -
I believe markers in Premiere will transfer to Encore, as will Vegas and DVDA communicate. CCE has a facility although I don't know if you can import them, or have to add them manually.
Jimmalenko is correct in that you don't add chapter points until authoring, however some encoders will use this information to ensure that you get I frames correctly positioned within the stream for accurate chapter placement at a later point.Read my blog here.
I am trying to split a *.vdr file by chapters, that's what I am trying to do. How could I do this?
Only .VDR file I know is a VirtualDub frameserver "signpost", and that can't be split by chapters. Take it from the top, explain what you start with, and what you'd like to end up with.
/Mats -
also - what mats.hogberg says is true ...
please explain what you are trying to do"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I am trying to make a colletion of some clips from some dvds, putting my logo in all of them at the same time. The virtualdubmod works with chapters I will find out how it handles them
Is there any Gop Mpeg Editor that while encoding from a frameserved file, can handle with a chapter list, and split this frameserved file by chapters?Originally Posted by BJ_M
sinc.,
J.J. -
no
chapters and I frame placement is what CCE uses the chapter list for...
but you asked about a GOP editor that would split a frame served file into pieces based on a chapter list ....
clearly not the same thing"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
Chapter list Menu problem with MultiAVCHD
By Jijital in forum Authoring (Blu-ray)Replies: 2Last Post: 23rd Feb 2012, 17:29 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 10:13 -
Can't control custom chapter list of tsmuxer.
By wisitch in forum Authoring (Blu-ray)Replies: 1Last Post: 26th Mar 2010, 04:08 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51
