You are supposed to start a topic for your question instead of posting in a unrelated (as far as I can tell) sticky topic.
Results 91 to 120 of 259
mkvextract does support vobsubs as I am pretty sure mencoder does.
I agree though, this thread is about hard encoding subs with VDubMod. You are asking about demuxing and using mencoder. Not at all that related. -
I've had this issue as well, I never had it until i installed the latest version of the programs, I'm not sure whether virtualdub or vobsub is at fault, since they were upgraded at the same time. However, it only affects .srt files, if you are working with a source that has multiple sub streams, see if it has a .ssa or .ass sub stream that you can use, or find a way to convert the .srt to that format. This seems to be a somewhat sporadic problem, rebooting before you begin or using virtualdubmod instead of virtualdub (or viceversa) might help.Originally Posted by ZeroHour
I have the same.Originally Posted by chinkymoomoo
I noticed that it only concerns Xvid files.
I've installed new codec but I didn't help.
I use VIrtualDub-MPEG2 1.5.10. -
how can I convert a movie that has vbr in audio to cbr so I can use vobsub?
because when I use virtual dub 1.6 with vobsub the sound is out of wack -
You could just use VirtualDubMod instead. Infact according to the title above me, that is what you are supposed to be using anyway. Personally I would demux the audio, sub using AVISynth and then remux the audio.
There was also a DSynth mod to AVISynth that would allow you to sub the video and direct stream the audio. Don't know if it has been updated lately though. -
I've looked around for this prob but can't find an answer, I'm sure it's something really simple staring me in the face, that I'm just missing.
I can add subtitles with VirtualDub as explained in the guide, but when I save the avi to folder everything looks like its going fine, but within in 2 min's the new avi being created is hitting a size of 5 Gig yes GIG. The film is only 6 mins in so even with a 100 gig hard drive I'm goiing to fast run out of space.
Please what have I done wrong or not checked surely the redone file should be the same size roughly as the original. -
Hi-
You haven't chosen and configured a codec (like XviD, DivX, etc.). You're saving it uncompressed. -
Originally Posted by Mithzamon
alltoavi worked great for me too.
it comes with default font arial size 12.
http://sourceforge.net/forum/forum.php?thread_id=1498318&forum_id=526958
this is the link that tells u how to change to subtitle size, it'll give the option of arial size 14, 18, 24 and 28 -
Hi...I have a .avi file...how do I create a subtitle file using SubtitleWorkshop or any similar software.
Thanx
Allan -
I tried it...it worked but the avi xvid quality is bad...lower than the source file...any idea how to keep the video quality?
I tried frameserving by using Mainconcept (because its fast on my pc)....no video comes out..only green screen.... -
The green screen is a bug in MainConcept where by it incorrectly uses XviD for colourspace conversions. Uninstalling XviD will solve it or use AVISynth instead of VDub.
Basically the only way to have the same quality, is to use a lossless codec (massive filesize increase). Using a lossy codec such as XviD, you can never have the same quality. That said encode at fixed quant 2 and you probably can't see the difference. If you are aiming for the same size though... The codec has to deal with the old artifacts, whilst trying not to create more. Plus subtitles are not very compressable. -
Finally I'm able to keep the video quality, still using Xvid compression..
In Video> Compression..choose Xvid, Click Configure and slide the Target bitrate a bit higher than the source bitrate (too high will result a bigger filesize)
Select Twopass if you want better encoding but it will take longer to encode..
But still..if you look really closely, you will notice some blurry around the subtitles...not really visible if you watched it on TV screen..Do you know why people mostly use Mac in their office?
Because a lot of stress can lead people to jump off the "Windows". -
Thanx many times this was probably the easiest way of adding subs..THANX A LOT!
I have coded it with DIVX so can u tell me how to convert it to DVD format now pls?
I know im noob wid these things i just started wid it -
DivXtoDVD. Or use ConvertXtoDVD and you don't need to use this method, add the video and sub and convert directly to dvd.
okay... i have 3 questions here... FYI right now i'm using VirtualDubMod and Subtitle Workshop to convert from softsub subtitle files to hardsub subtitle files.
1) I try to edit the font in the .srt files to the colour version (for special purpose) but when i'm try to save it into .ssa files it seem not working. same thing happen when i try to edit the font of .ssa files to colour version... any program that can support the version???
2) how to make the subtiltle appear above and bottom of the video at the same time???
(to show the meaning of word, phrase, etc)
3) i've noticed that VirtualDubMod do not support and can't compressed Xvid file... is there any other program like VirtualDubMod to deal with that situation?
thank you. -
Hi-
1) I haven't used Subtitle Workshop, but SubStation Alpha can create or edit SSA subs keeping color, font, size, position, etc.
2) In SubStation Alpha create 2 subs, one for the low center position, and the other for the high center position.
3) If you have the XviD codec installed, VDubMod can encode to XviD quite easily and well. -
Hi Baldrick and many thanks for the guide.It is perfect but i have a question:
When the movie is widescreen can i put the subtitles under the movie (in the black field)?
You need to convert subs to SSA format, which supports positioning of the subs. Then it's a matter of trial and error to get the right placements as it depends on the font sizes and all that.
How can i add 2 permanent subtitles upside and downside the video?
By farzad67 in forum SubtitleReplies: 19Last Post: 6th Feb 2013, 12:38 -
how to add permanent subtitle to avi video?
By Sh@DY in forum SubtitleReplies: 4Last Post: 4th Oct 2011, 12:41 -
How do I add permanent subtitles 720p MKV video
By Torresinho in forum SubtitleReplies: 1Last Post: 15th Sep 2011, 20:16 -
How to add permanent subtitle to mkv
By ybe in forum SubtitleReplies: 0Last Post: 6th Aug 2010, 18:01 -
How can I add permanent subtitle in TS file
By elmc in forum SubtitleReplies: 8Last Post: 19th Jul 2008, 03:32
