If you are just encoding video, then regular VDub is fine. Can't see any reason why you couldn't use VirtualDubMod instead though, they are basically the same in terms of usage.
You should definatly have the filter on for both passes. Same goes for all filters.
Results 61 to 90 of 259
Hello I'm having trouble putting in about 5 .ass files into one of my .avi you see, When I put them in with the new sv filter 2.37 or w/e and I add them to my .avi (divx 6.1) and encode it in xvid 1.1 like right after about 3 seconds of the video it lags for a second then the sound is off and the video is as choppy as hell. I was wondering what the problem is. I was wondering if someone could tell me what the correct fps's are for .ass file and how to tweak my xvid settings to fix this. This is funny cause when I play it on my virtualdubmod in "file > preview output form start" it does lag or anything, but when I encode it it lags. Please help me!
Thanks for the guide ! It does really help ! I just have couple questions. Is there anyone know why the new avi file comes out seem smaller than the source ? I put in a 700MB video it comes out around 400MB . Is there any way to keep the same quality, I dont mind the larger files ...
Using the same bitrate, will give you the same size, but not quality. For the same quality, the size would have to go up since a) you are recompressing and b) subtitles are hard to compress and you are adding them.
I followed the instruction but when I open my video file in VirtualDubMod, I have an error message
Can't locate decompressor for format XVID( unknown). VirtualDub requires a Video for Window(VFW) compatible codec to decompress video. DirectShow codec such as those used in Windows Media Player are not suitable. Only 'Direct Stream copy' is available for this video.
Please let me know what. I am new at this so dont understand much so please keep it as simple as possible. Thanks for your patience and all the help -
What OS are you on? I had the same problem when I was on Win98. I ended up compressing to Microsoft MPEG4 V3 (which can also be played by XVID)
Help!!!
I'm using VirtualDubMod to permanently add subtitles to my .avi file. But an error occurs when I try to save it as a new file. The error that pops up is:
Error decompressing video frame 0: An unknown error occurred (may be due to corrupt data). (error code -100)
Does anybody know a way that i can deal with this? Thanks so much for any help that i can get!!! -
Error decompressing? Sounds like original file's corrupt, but that wouldn't make any sense...
Then how can I keep the quality the same ? I dont mind the bigger size thoug h ! Thanks ! 8)Originally Posted by celtic_druid
Hi
Just want to drop by a thanks for this very nice guide!
I've got a lot of .ogm and .mkv files that I want to play on my DVD-player and my Zen Vision:M, and to do that I need DivX/Xvid files with subtitles (mostly anime, and my japanese is kinda... bad ^^).
I had no problems demuxing the audio and subtitles, but I couldn't seem to be able to code the subs into the .avi file afterwards, but thanks to this guide I'm now able to convert all my files without any problems at all!
Thanks a lot, really useful for me.
or use alltoavi, all-in-one mkv, ogm to avi with subs.
Originally Posted by Baldrick
Woah, that's awsome. I really should've checked around a bit more on the site ^_^ Giving it a go now.
Edit: AlltoAvi works pretty nicely, the only thing I'm wondering about is if it's some way possible for me to change the font size of the subtitles? -
THANK you for this! I'm using VirtualDubMod to permanently add subtitles and it works GREAT.
One thing: what if I have a .srt. that does not sync with the .avi? Can I do something about the .srt timing in VirtualDubMod (like to start a 1-2 seconds later...)?
TIA -
I have the same question as 'HomelessBird'. Fansub groups for asian drama and anime have files that are 700 MB and when they encode them, the files still maintain at 700 MB. The quality seems to be the same, also. Did they use separate streams or something to keep the quality and size the same? If so, is there a guide for that? Thanks in advance!
I had the same problem. When I tried to convert a DivX video to Xvid it said "Error decompressing video frame 0" and I just clicked the "Video" menu, clicked on "Error mode...", and selected "Decode even if the result may be garbled". After I did this, I no longer got the error message. I didn't let it convert the whole thing because as soon as I saw that the error message didn't pop up, I just stopped it. So I don't know if it will work out 100%.
i have this problem too, i still cant get it workingOriginally Posted by JoeyR
i am really clueless with these thigs, can someone please tell me what to do, because when i laod my avi movie i get that error,
sorry kinda new at these thigns
hope you can help me
This method works very nicely to make DivX files of interviews recorded from TV and subtltled from a text translation. Thank you!
But is there a way to change the output resolution to 640 x 480 instead of the default 720 x 480? It seems to be locked at that size.
640 x 480 creates a more accurate looking aspect ratio when played on the computer. -
add a resize filter under video->filters and resize to 640x480 and use lanczos resize.
Wow! fastest response ever!Originally Posted by Baldrick
That ought to do it perfectly, thank you!
(Does the order of the 2 filters make a difference in performance or quality?) -
Thanks Baldrick & Abond. That worked great.
Next project: Using VirtualDubMod to grab a segment from a DVD, I'm trying to hard code the subtitles into the AVI. I added VOBSub 2.23 in the filters, opened the IFO file for the VOB video file that's been opened. It finds the English subtitle stream and opens it, but I don't see the subs in the Output Preview. What's the trick?
If somebody knows where to find a guide for VOBSub 2.23, it would help. I can't seem to figure out how to use the location box shown at the right side of the filter configuration dialog. It makes no sense to me. I'm sure I'm missing something obvious that's causing the subs not to appear. Thanks!
EDIT: Further searching brought up this guide: http://www.nanomessiah.com/dvd-backup/vobsub.html
which I folowed exactly, but I still don't get any subs. Hmmm. -
Well, I'm entirely sure if this is the thread where I should ask this question, but maybe somebody here can help me out. I have some mkv files, i have encoded the video and audio to avi using mencoder, but the subtitles didn't come through (even though it was set to encode those as well), and upon further examination, I discovered that the subs are of type (S/ VOBSUB) according to mkvextractgui, and mencoder is ignoring them because it doesn't recognize the type, also, I can't use mkvextract to extract the subtitle stream, because it doesn't recognize the format either. If anyone knows how to extract this type of sub and encode it into the avi, please let me know.
How can i add 2 permanent subtitles upside and downside the video?
By farzad67 in forum SubtitleReplies: 19Last Post: 6th Feb 2013, 12:38 -
how to add permanent subtitle to avi video?
By Sh@DY in forum SubtitleReplies: 4Last Post: 4th Oct 2011, 12:41 -
How do I add permanent subtitles 720p MKV video
By Torresinho in forum SubtitleReplies: 1Last Post: 15th Sep 2011, 20:16 -
How to add permanent subtitle to mkv
By ybe in forum SubtitleReplies: 0Last Post: 6th Aug 2010, 18:01 -
How can I add permanent subtitle in TS file
By elmc in forum SubtitleReplies: 8Last Post: 19th Jul 2008, 03:32
