I was editing a pal mpeg2 (352 x 288) video with Tmpgenc editor. Everything seemed to go fine, audio synchs fine.
At the moment i'm teaching myself using scenarist, though i am very capable with Dvdlab Pro. Whilst, the mpeg2 loaded fine into dlp, and basically compiled fine without any problems, when i imported into Scenarist (v3), it spitted the file out saying
"Error : Number of fields (36) in GOP(# 3790) or between sequence_header_code should be equal or smaller than 30."
What software, would easily allow me to locate GOP's by searching by GOP number? Its not a matter of simply multiplying 3790 by 15 to find the rough frame number, because some of the gops won't be automatically be 15 frames long, on the contrary, some are 13.
Is there software to search on GOP# easily? So i can begin to repair the gop structure for this file.
Some people are only alive because it may be illegal to kill them
I wish I had $20,000 just to learn a new toy . . . . Ah well.
Mpg2Cut2 says it is a GOP level mpeg cutting tool, so it might be worth a look. Otherwise look at something like cuttermaranRead my blog here.
I'm sure if i had have $20,000 laying around i wouldn't bother buying scenarist. A friend of mine (a very wealthy friend i may add) was a scenarist guru, and he recently developed motor neuron syndrome. Of his friends in the business, he couldn't be bothered helping them out, and as he knew that i was getting really into this dvd stuff, he gave me his workstation with the scenarist installation on it. It was a wonderful gift, but he did communicate to me that it wasn't the most pleasant gift - he said you gonna have to learn a lot!!
But anyway, in regards to the initial error... i went back into tmpgenc editor, and played around with it and it just moves an error somewhere else, so i'll try out cuttermaran.Some people are only alive because it may be illegal to kill them -
tried it. it was clumsy for what i need to do. But thanks
I need help with open gop i think
By Rathgar in forum Newbie / General discussionsReplies: 7Last Post: 13th Jan 2012, 15:29 -
google search pages keeps erasing my search criteria -- [RESOLVED]
By vhelp in forum ComputerReplies: 0Last Post: 5th Mar 2011, 16:27 -
Which GOP program?
By pboong in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 12:19 -
Search Excel Spredsheet Data in Vista Search
By mn072065 in forum ComputerReplies: 11Last Post: 29th May 2009, 00:26 -
Question about search engines that search Rapidshare
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 9th Nov 2008, 03:08
