as well kown, most professional video edit system only support its own
format except adobe premiere. So my own divx avi file can not import those system.
some one told me that many system can support DV50 format file.
So, I want to konw how to write a dv50 file? what is the format of dv50
file? what is the codec or header info of dv50 file? and so on......
any answer will be appreciated!
(I am talking about the broadcasting type apps. and want to develop a tools which convert nonDv50 file to be DV50 file.)
dv50 = divx 5(.0)
either download the divx codec, or better yet, download the xvid codec and have it do it without the spyware..
there is no need for angry faces..
You are using a lot of forums to get your answer, aren't you?Originally Posted by hdzhang
As DV50 is a different (better) DV format ( http://www.adamwilt.com/EBU-DV.html ) there is no real use to convert DV25 or even DivX to DV50.
Dx50 != DV50 (@poster above) -
DV50 is the 4:2:2 50Mb/s version of DV used by DVCPro 50 machines. DVCPro 50 uses 3.3 to one compression vs. 5:1 for normal DV25.
Those machines usually interface a computer with hardware SDI interface cards using uncompressed 8 or 10 bit 4:2:2 SMPTE 259M-C at 270 Mb/s. DVCPro 50 machines are 8 bit as I recall. Digital Betacam is 10bit.
I'm unaware of a DV50 file format for the computer. It would just be stored as uncompressed 4:2:2 CCIR-601 (ITU-R BT.601).. -
DivX might not be supported as it's not a standard codec used in editing -- it's more of a hobbyist's video collection codec. Check and see if they can take standard DV (DV25) which would be easier for you to convert to.
DV50 to WMV3/9 encoding = fail
By Hazarath in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2010, 17:03 -
Camtasia Error : "Unable to write AVI file frame"
By ShinuMirai in forum Newbie / General discussionsReplies: 8Last Post: 11th Oct 2009, 16:19 -
vlc - where does it write it's log file?
By minidv2dvd in forum ComputerReplies: 2Last Post: 31st Jul 2009, 11:48 -
Write Speeds - anything new?
By Mike99 in forum MediaReplies: 22Last Post: 10th Feb 2009, 20:41 -
What Format did I write in
By TechJD in forum DVD & Blu-ray WritersReplies: 5Last Post: 30th Jan 2008, 20:24
