Downloaded a dvd from a legit site, it plays fine on my PC, but when I burn it my stand alone dvd player shows a series of static images, changing every 30 seconds or so. Audio is playing fine. Details from AVIcodec on the vobs are :
Video : 1.18 GB, 9000 Kbps, 25.0 fps, 720*576 (16:9), MPG2 = MPEG 2 (SVCD/DVD), Supported
Audio : 34 MB, 256 Kbps, 48000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
Any suggestions what is going wrong here?
Cheers
Maybe your stand alone dvd player doesn't like the type of media your using. Can you try it on another dvd player?
Thanks for the reply, sorry for the delay in posting again.
The dvd when burned will play on a friends dvd player with no problems.
I have tried 3 different branded discs and all have the same issues with my player.
I was wondering if there was anything I could try, eg. recoding, that would be likely to help. (I don't mind losing some quality if I can play it!!)
My dvd player has never had this problem before and has played every burned disc without problem.
Cheers
How do I put static version of website on DVD?
By net4ward in forum Authoring (DVD)Replies: 3Last Post: 16th Jan 2012, 15:03 -
jerked images after burning DVD
By Ilovm in forum MacReplies: 3Last Post: 26th Jun 2011, 17:49 -
Philipps DVP3360 DVD player displays STOP / ROOT
By offytuf in forum Newbie / General discussionsReplies: 0Last Post: 22nd Mar 2011, 17:06 -
Multiple displays
By alintatoc in forum ComputerReplies: 2Last Post: 18th Dec 2010, 17:53 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45
