When I try to convert a wav file I have to mp3, the mp3 comes out really slow. It sounds like its in slow motion. This happens no matter what program I use. I have no idea what to do. Any help at all would be appreciated. Thanks in advance.
What sample rate(44.1,48,etc) and bit depth(8,16,24) is the WAV?
Right-click on the file and select Properties,some converters have a problem if the WAV isn't 44.1kHz/16bit.
Try www.cdwave.com or Goldwave to convert. -
Heres what my file says:
Bit Rate - 5644kbps
Audio sample size - 16 bit
Channels - 8 (how is this possible? my file is in stereo, isn't that just 2 channel?)
Audio sample rate - 44Khz
Audio format - PCM
I tried to burn my audio to a cd, and it said it was 91 minutes long, when its really only 24 minutes.
why is ffmpeg breaking my WAV when converting it to MP3?
By charlieship in forum AudioReplies: 0Last Post: 26th Sep 2011, 17:56 -
converting WAV to MP3 and preserving timecode
By soundie in forum AudioReplies: 3Last Post: 2nd Jul 2010, 13:33 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
Converting WAV/MP3 to DVD-compatible sound file
By Erasmus in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2009, 21:41 -
Converting WAV to MP3
By igorek in forum AudioReplies: 5Last Post: 1st Jun 2008, 20:25
