hi
I have a freeview box with a scart output, and 2 audio outputs
I wish to link them up to my Leadtek 200XP deluxe TV Card
I bought a SCART to S-Video and 2 Phono cable to connect the freeview box to the tv card
The aerial in is connected to the freeview box, the aerial out is connected to the aerial in of the tv card, the scart out is connected to the s-video connector on the adapter that came with the tv card
I have loaded up PVR and tried CVBS and S-Video, but all i get is a blue screen
Any suggestions? I've tried everything I can think of!
What kind of SCART adapter (Cables?) are you using?
You need one which you can use for output.
(Most adapters you can switch between input/output)
Also you must be sure the freeview box supports S-Video out or can be configured todo so.
If not, you have to use the composite connection. -
im using a JVC Scart to 2 Phono + S-Video Cable
and I have no idea how to check or to do the latter 2 things you mentioned -
If your Freview box is anything like mine (Alba) it doesn't do S-video from the Scart output or anywhere else! My box does RGB and composite and nothing else. A Scart to S-video lead doesn't convert the signal, it has to be in S-video format to begin with. This is normally achieved via a slider-switch or menu setting on the box and if you haven't got these you're screwed.Originally Posted by p_cowell141
Yes, a SCART out to 2x audio and 1x composite phono/rca should work.
Freeview box failure?
By aw56001 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 3rd Dec 2011, 09:22 -
Had freeview, Now it's gone!
By Squid_uk in forum Off topicReplies: 2Last Post: 23rd Sep 2009, 04:05 -
3.5" HDD into Freeview?
By Nitro89 in forum ComputerReplies: 3Last Post: 29th Apr 2008, 10:52 -
Upscaling Freeview/DVB live TV to HD
By Lovepeaceguru in forum DVB / IPTVReplies: 11Last Post: 24th Dec 2007, 07:37 -
my freeview--no event info.
By ssaamm in forum Newbie / General discussionsReplies: 0Last Post: 26th Jun 2007, 14:33
