How do I know what to set it in my bios? I have an AMD 2200+ on a EP-8rda+ motherboard. It's set at 133...but I'm wondering if I should be setting it higher, or if it would make a difference. I have never really played with my BIOS so I don't know what to do...if someone could provide links as to where I could study up on it.
Smile
Smile -
It depends on your motherboard and memory where you can set it. I run 2 different boxes with AMD 2200+ Semprons OC'd to 1863Mhz from the stock 1583Mhz. The Sempron is rated at 333Mhz FSB, but I have OC'd four of them so far to 400Mhz FSB, all stable and still operating. One motherboard is an inexpensive Chaintech SKT600 and the other a ASUS A7N8X-E. The memory in both is economy type Corsair Value Select DDR400/PC3200.
The only change I made was to set the FSB to 400MHZ (392Mhz). Stock CPU coolers in both machines. The ASUS runs pretty much 24hr/Day for the last 3 months with no heat problems, completely stable. Chaintech with no problems either.
If your MB is up to it (400Mhz FSB option-set the system clock to 200 instead of 133) and your memory is 400Mhz, shouldn't be a problem. If nothing else try 166Mhz system clock, that will give you 233Mhz FSB and that will work with most systems. Some MBs have a jumper to change and some do it in BIOS-Check your MB manual.
EDIT: And yes, it will make a difference, even the 166Mhz system clock setting.
EDIT: Looks like your MB will run at 333Mhz FSB. You set it in BIOS. Just go from 133 to 166Mhz and you're done. I wouldn't mess around with the multiplier unless you really know what you are doing.
Need to capture in 60hz frequency
By Teryolilio in forum Capturing and VCRReplies: 18Last Post: 21st May 2010, 11:58 -
Frequency response correction
By siluet in forum AudioReplies: 6Last Post: 29th Jan 2010, 15:44 -
Need to find out FSB speed
By Eyecan'tcode in forum ComputerReplies: 11Last Post: 18th Jun 2008, 19:22 -
Is noise frequency cancelling possible this way?
By Shoyriazu in forum AudioReplies: 3Last Post: 31st Jan 2008, 07:13 -
Matching CPU/Motherboard FSB to RAM Speed?
By rkr1958 in forum ComputerReplies: 2Last Post: 24th Jul 2007, 22:25
