Is it posible to demux a DVD and add another audio or subtittle?
If it is, is there a guide or a list of programs that I could try?
ReJig lets you demux video and audio out of a (or a # of) VOB(s). Once you've got these 2 ingredients, it's just a pure authoring exercise.
/Mats -
To add subs or audio to a dvd:
Dvd decrypter
Dvd lab or muxman
Before using dvdd you need to go to tools, settings and then on the ifo mode tab check the option&-chapter information-dvd lab-
Load your dvd, select ifo mode the small screen on the right will change, click on stream processing and then select what u want to demux and demux the dvd
Open dvd lab, load the video and audio streams that dvdd created and add the subtitles you want, also import the chapters points that dvd decrypter created when demuxing the dvd
Instead of using dvd lab you can use muxman(freeware) with a more simple GUI.
You will se what I mean when you use it.
You can set up chapters in muxman.(copy/ paste the chapters points dvd decrypter created)I love it when a plan comes together! -
I try to demux a dvd but when i mux them again the video shows late
By sky-walker in forum Video ConversionReplies: 5Last Post: 25th Mar 2010, 14:11 -
How to demux a remuxed dvd ?
By WinSpecToR in forum Authoring (DVD)Replies: 2Last Post: 18th Feb 2009, 17:56 -
easiest way to demux audio from DVD then add it back in?
By fotty in forum Authoring (DVD)Replies: 4Last Post: 12th Jun 2008, 09:46 -
Demux DVD Video to separate M2V and AC3 files
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 3Last Post: 6th Oct 2007, 21:03 -
demux DVD Video to MPG!
By GangstaRap in forum Authoring (DVD)Replies: 10Last Post: 8th May 2007, 18:45
