I will be running this speaker wire inside the wall's. Not sure what Kind to get, They will run from a speaker (Wall Plate) to another speaker ( Wall Plate). This is for my home theater.
Results 1 to 9 of 9
There's a special grade for running inside your walls - has to do mostly with the covering of the wire and if there's ever a fire. Check with your local Home Depot - if the clerk tells you that you can use normal wire then find another clerk that knows what he's talking about.
As for the wire gauge - it depends on your amps power and the cable length.
If you're needing longer runs pick up the wire from an electrical supply house (like Westburne Electrical), they usually sell in 1000 foot rolls - you'll probably need to determine the type and gauge prior to going to the supply house.
I help wired a friends home with CAT5 and RG6 (net and cablevision) and found the 1000 foot rolls were about the same price as 200 foot from Home Depot (but prices change all the time). -
"plenum-rated" cable is what it is called.. In canada it is FT6 cable (that is a rating, not a cable type)
FT4 can be used for short runs ..
this is the law in ontario and it is pretty well the same throughout canada
http://www.obc.mah.gov.on.ca/userfiles/HTML/nts_4_9983_1.html"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
SquirrelDip is right - most places do not know this ...
also many houses are not wired with ft6 cable for cables by the builder (legally) because it is classed as single conductor wiring .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks for the tips.
The total Feet per Wire will be 22 Feet, I was thinking 18 gauge oxygen free, But I have heard there is no difference. I'll try going into a home theater Store. -
you will pay up the nose if you buy cable at a "theater store" , the markup is 100-300%+ often --and it is no better quality....
just use a tight jacketed twisted pair 12 or 14g - 18g is way to light and you will lose a lot of damping factor .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
If you are really worried about have the wires exposed, you could always run it through some PVC type conduit or the like. This would also aid in the future if you ever decided to upgrade (for example, fiber optic digital speaker system...etc).
PVC type electrical conduit is not legal in the walls in Canada, it has to be EMT or equal, or BX or Romex/NM/NMD - though it (pvc conduit) is used in Europe and Asia a lot ..
Originally Posted by BJ_M
Unless you concrete encase it...
Speaker wire to RCA? cable needed...
By flamy in forum AudioReplies: 12Last Post: 24th Dec 2010, 12:05 -
Edited sound jumps from speaker to speaker
By len hend in forum AudioReplies: 3Last Post: 23rd Jul 2010, 05:49 -
speaker wire issues.
By Shikhar in forum DVD & Blu-ray PlayersReplies: 6Last Post: 2nd Jul 2009, 09:23 -
To Wire or Not to Wire?
By mblanco2000 in forum Media Center PC / MediaCentersReplies: 10Last Post: 7th Mar 2008, 19:26 -
Power supply wire management
By Video Head in forum ComputerReplies: 4Last Post: 14th Feb 2008, 16:03
