got 128mb memory with 233 speed and bought another 512mb with 400 speed. can i insert them both in my memory slots? the tech told me that inserting both might result in pc crash or a more slow computer...i remove the 128mb and inserted the 512...but i dont know what to do with the 128mb i think it's a waste if ill just throw it away since i can't sell it.
hacking the Net using typewriter :D
although i'm far from being an expert in this area, i suggest that the memory will run as fast as the slowest ram module, in this case 233. 512MB is just about the minimum these days, and i suspect that 640MB running slow would be worse than 512MB running faster. Just run a couple of diagnostic software tests on each config to see which one is best is about the best advice i could give you.
Some people are only alive because it may be illegal to kill them -
guns1inger is right. the 128MB wirh 233 speed with be the bottleneck.
Use the following info on how to check your new memory modules.
http://www.mrbass.org/dvdnewbie/Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic
Is there a speed rating on sony memory sticks for video playback on psp?
By yoda313 in forum Newbie / General discussionsReplies: 0Last Post: 29th Jan 2011, 21:12 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31 -
question about USB download speed into memory stick
By jimdagys in forum ComputerReplies: 2Last Post: 7th Oct 2007, 20:38
