I have just edited two MPEG2 files (total length 1.5 hours) and Ulead Video Studio 8 wants to re-render the whole lot, not a smart thing to do to MPEG2!
The files in question were produced fom Mainconcept - latest version, same VBR bitrate (8 Meg max ), same MP2 sound setting, same template even. I have check Project properties and Ulead preferences against the files and they are the same.
I have done this in the past with no problems but as I must have this finished by Wed, I am getting a little exasperated and am running out of magic to try. Any ideas, even editing the VSP file with a Hex editor is an option if someone can tell me the file format.
Just to let everyone know what my problems were -just in case others have suffered as much as I have done!
Problem 1: I had made the soundtrack on the source files ac3 instead of mp2 - a step I usually do after editing.
Problem 2: The max bit rate written into the headers of source file 1 was 9,75 Meg. I reduced it to 8 megs with some freeware software.
Note: If both these fixes where not applied then the whole project was re-rendered and I must say that this was a right royal pain to find. I think Ulead should document smart render better as I must have gone through dozens of trial and error exercises before isolating the right magical mix to get it to work.
CAN ANYONE RECOMMEND A 'SMART RENDER' PROGRAM FOR .ts VIDEO FILES?
By QDM in forum EditingReplies: 1Last Post: 12th Jan 2012, 15:49 -
h264 smart render problem
By wentwog in forum EditingReplies: 2Last Post: 18th Aug 2010, 15:26 -
How to smart render a VBR in Vegas?
By schematic2 in forum EditingReplies: 10Last Post: 12th Mar 2010, 11:25 -
h264 problem in Sony Vegas and Ulead Video Studio
By AscAnsio in forum EditingReplies: 1Last Post: 8th Jan 2010, 09:49 -
How to smart render divx in TDA3 ???
By Xnici in forum Authoring (DVD)Replies: 4Last Post: 25th Jul 2007, 10:41
