Ok, here is my issue. I have an avi fle that I want to encode for DVD. When I load the AVI into Vegas video the video is longer than the audio(The avi plays fine with no sync problems). I trimmed the extra off before encoding but when I demux the two and load them into DVD Architect for authoring, the files are still not even. Any help would be appreciated.
It would be of help if you could tell us what kind of audio your file contains... MP3 VBR? AC3? ??
Often certain applications will report the wrong length for your audio when in actual fact the track is just the right length. Not sure about Vegas though (I doubt it)
So load up your file in GSpot for instance and let us know what it says.
A couple of other considerations on this: would you by chance have been trying to join 2 avi files, and/or perform PAL/NTSC conversions? All this can affect synching issues big time.( i.e. your file is 25 fps and your end video is 23.976 fps or vice versa).
Demuxed Audio is longer than Demuxed Video, help!
By caesarhawy in forum EditingReplies: 3Last Post: 26th Apr 2010, 04:18 -
Audio in MKV files goes out of sync when demuxed
By carlmart in forum Video ConversionReplies: 11Last Post: 29th Oct 2009, 06:18 -
Demuxed VOB into M2V and AC3 -- Sync issues
By jj_30 in forum ProgrammingReplies: 0Last Post: 16th Jul 2009, 12:38 -
(MKV) Audio/Video synching problems after remuxing the same files I demuxed
By Sigma X Virus in forum Newbie / General discussionsReplies: 3Last Post: 9th Feb 2009, 16:27 -
Demuxed Delay Help
By Nitro89 in forum AudioReplies: 22Last Post: 16th Apr 2008, 14:06
