  1. IS posible to make a SVCD With multiangle video?.
    What software can do this?
    THanks
  2. I don't think so, on DVD each angle is a diffrent variation of the movie, which means the movie is usually on the DVD several times, if you try that with SVCD (if it was possible) then you won't have any space for any decent length of movie.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
    Jul 2001
    Germany
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    That's not how multiangle works. usually if you have multi-angle, you have some more scenes or other scenes somewhere in the movie. If you would put this as an additional movie on the DVD, that'll be too much for most movies. Instead DVd uses a technique called seamless branching. it's almost like chapters, that are played or not, regarding what angle you play. just that it isn't called chapters. There is a kind of playlist that says "play this, this and this". and there is no pause between the parts.
  4. There are movies where you got the movie several times, either that, or the same scene is located several times, the idea is the same, branching is not supported (as far as I know) on a VCD or SVCD, it's a DVD specific ability.
    Best Regards,
    Sefy Levy,
  5. Thanks to both of you for the information:
    I will reformulate the question. If in theory it is not possible to create a video file with multi-angle in a cd-r. Does any program exist that will allow me to create my own dvds (dvd-r, dvd-rw, or something of this nature) with multi-angle?
    Jul 2001
    Maryland
    I've seen some DVD's with a widescreen and full screen version on the same disk
  7. I'm afraid i'm out on that one, as I don't have a DVD-Writer i have no information regarding any of the DVD Authoring programs although i'm quite sure there should be something for that purpose.
    Best Regards,
    Sefy Levy,
