I'm trying to convert about 40 mini DV tapes to DVD but I want to be able to edit the footage at a later date. If I use a stand alone recorder and it converts the footage to MPEG, will that screw me up? Do I have to capture to my hard drive and save segments as avi files? Is there some brand of a stand alone DVD burner that will allow me to quickly burn the footage and deal with it later? I have a laptop (512, centrino) and I would need an external burner. Also, USB 2.0 connection or Firewire? Thanks in advance for your help!
Results 1 to 10 of 10
.....and save segments as avi files?
...will allow me to quickly burn the footage...
THink of water and ice..
In essence, your DV tapes, .AVI, and editing requirements are all at your fingertips..Sort of pouring water into different shape glasses, or cube trays..
MPEG (the guts of DVD) is a final format. Sort of like ice. It wasn't intended for editing..
It's easier to manipulate water, to produce round ice cubes..When editing Mpeg, it's like taking round ice cubes, and making squares out of them..NOT FUN.
Good luck!!! -
Originally Posted by pijetroThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks for the quick reply! Pijetro, great analogy!
I agree with everything you said....the problem is that I have 40 tapes and stuff is all over the place. They're not organized at all. So what I wanted to do was go through all the tapes and organize the footage. So this DVD has stuff from girlfriend X, this tape has stuff of my grandfather, etc... then, when I'm ready to edit them (could even be a couple of years) I'll import the "grandfather" footage from that DVD and start editing.
So is there a quick way to organize all the footage? Turn everything into avi files and save them to DVD as a data disk?
I still want to keep my mini DV's as backup. But sometimes people will ask me, "Do you have any video of your niece?" And of course, I do but it's on tape 3, tape 12 and tape 32. It would be great if I could just pop in the "Niece DVD" and choose which segment to watch. Then, at some point in the future, I could make a nice polished movie with music, titles, transitions, etc.. and give it to her...
So I guess I'm trying to figure out if there's an easy way to do this. Or am I going to have to sit there and go through each tape, capture the footage, name the avi file, keep capturing, etc...I'm freakin lazy! What can I say!
Thanks so much for all your help!!!!
-Scott- -
WinDV can be configured so that it captures each clip into separate AVI files.
But, I'm sorry to say, that I don't know of anything that will do any more than that.
And "girlfriend X"!?!?!? How many do you have at one time? And I daren't ask what the videos of...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Seriously, if i were you, i'd invest in harddrive space..Capture whatever you can. Cut, keep or move different footage, and re-export to tape..
That way, you can exclusively have Uncle Phil on one tape, the family barbeque, on the other, and the Tommy Lee and Pam footage on the other.
Good luck!!! -
Thanks for all the help and the WinDV tip....Everyone who offered suggestions will get one free copy of a tape. Just specify which girlfriend.... A-Z!
I guess I'll just have to sit there and manually capture each tape. Does anyone know if there are any stand alone DVD recorders that will burn avi on the disc instead of MPEG? -
Originally Posted by scottallen
DVD Recorders use analog or digital cable/satellite/terristic signals and convert them to mpeg2 (that's why they called DVD recorders). The new SONY has DV in, but what do you gain, using a DVD Recorder? -
Setting up WinDVThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Here is what I'd do. Two ways.
1. "Capture" transfer each tape in segments to avi files. You could fit all 20 tapes on one 300GB drive but you will probably find you can skip over at least 25% as useless.
2. Separate segments by categories as you see fit in disk folders.
3. Copy folder contents to tape (60min chunks) or as files to DVD (20min DV-AVI chunks) until all is backed up. I'd add a slate at the front of each clip to help with content identification later.
Alternatively,
Log and note tape contents to an Excel spreadsheet. For every DV tape enter tape id, timecode, category, segment contents and date.
That way you can qwery the spread sheet for the clips you need when the time comes to edit.
How do I keep the Avi quality from mini-dv when converting to DVD?
By jbitakis in forum Authoring (DVD)Replies: 12Last Post: 28th Apr 2011, 23:52 -
converting DVD mini disk files to compatible APPLE format- video is missing
By MovieMom in forum Video ConversionReplies: 2Last Post: 5th Sep 2010, 13:33 -
Converting DVD to Mini DV - and it gets more complicated
By NSP in forum Video ConversionReplies: 13Last Post: 12th May 2009, 04:13 -
DVD Editing from Panasonic VDR-D220 Mini DVD and interlacing problems
By gbnz in forum EditingReplies: 3Last Post: 15th Oct 2008, 14:34 -
help in converting mini dv cassettes to dvd
By imager849 in forum Newbie / General discussionsReplies: 6Last Post: 18th Mar 2008, 20:15
