Can anyone tell me what Media Portal is and what it does?
Results 1 to 9 of 9
Looks like its the name of a piece of software for HTPC, basicly a PC that works with your TV. Provides TIVO like functions as well as play files on your TV. Photos and other stuff.
Kinda like a TIVO but more powerful.
I think thats what you mean. -
So are you saying that its a software that allows you to veiw your HD using your TV as a monitor?
Oops, wrong app.
No tengo miedo a la muerte. Solo significa soņar en silencio. Un sueņo que perdura por siempre. .. -
OK let me ask like this. Given that I can veiw movies, dvds, listen to mp3s, listen to internet radio, and internet TV right now on my PC without media portal, What would I be able to do different if I were to install media portal?
Without media portal, what is it that I wouldn't be able to do? -
It's not really an app for a PC. It's a PVR.
Hook up your computer to your TV, run mediaportal, and do everything with the remote on the TV.
BTW, you DO need to have a capture card to use it properly.Cheers, Jim
My DVDLab Guides -
Well, its an app that turns your PC into a PVR.
It's a floor wax AND a desert topping!
Interesting some of the comments think it's wonderful that it is updated every few days, while for me this marks it as something to avoid.
Primary characteristic of many such programs is text and menus that are readable on the TV screen and usable through a remote. Highly user-specific. -
Because it's open source, many people work on it.
The daily updates are usually just skins, or adding new tuner cards to it's support, not major programming updates.
It's a BEAST that devours RAM faster than anything I've ever seen, Including windows, but it does have a pretty interface.
Cheers, Jim
My DVDLab Guides
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 06:07 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
extra dimensional portal appears over norway!!!
By deadrats in forum Off topicReplies: 4Last Post: 10th Dec 2009, 20:03 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 18:58
