hi,
trying to convert some mpeg2 tv 16:9 captures to xvid, somehow Vidomi is acting up, xmpeg too so im trying tmpgenc express "output to .avi".
im selecting xvid, 1st pass, 2nd pass configure, then audio - lame @160, hit convert but it ends up with a file almost as big as the source?!?!
ran it thru gspot it reports it being an xvid .avi allright but the bitrate is like 10mbps?!
please help![]()
Results 1 to 16 of 16
im using tmpgenc xpress because nothing else works...vidomi breaks up, virtualdub i can't seem to find the audio compression options, dr.divx was a trial now expired and divx6 converter sucks. I might try flaskmpeg or xmpeg again tonight.
Somehow it worked out with tmpgenc but the resulting file was tiny this time and had a bad quality even at 1300kbps bitrate. Is there a way to make xvid automatically start the 2nd pass after the 1st one? dr.divx was really the best for me...
i have 3 files, 1 pregame and 1 for each game half, totalling around 7gb. total runtime around 2hrs. I want to maybe merge them into one before converting to divx/mpeg. What would be the best way? To create 2x700mb files the bitrate would be around 1500kbps for a 2hr material... -
Virtualdub - set video to Full Stream Processing, then set the compression on the save dialogue.
Read my blog here.
I am sure you mean VirtualdubMod, regular virtualdub will not open mpeg-2.Originally Posted by guns1ingerThere are 10 kinds of people in this world. Those that understand binary...
i found that out myself tooOriginally Posted by bugster
normal virtualdub complained about some frames missing from the mpeg2. The virtualdub mod opened it okay, but as i said i could only find the video compression function. I'll try tonight as suggested by gunslinger...although i think default is FSP, not directstreamcopy (i already did that). So basically do 2 jobs, one for 1st pass (resulting in the huge file), 2nd on 2nd pass, right? How can i join the 3 mpegs and cut out some commercials before i encode to xvid?
use virtualdub-mpeg2, it is same as virtualdub and you will find the audio->compression....
dvx crashesOriginally Posted by Baldrick
avi.net doesnt want to load the mpeg, errors out with "error creating index file"
virtualdu(m)b doesn't work either with xvid, no matter what settings i choose for 1st or 2nd pass it always gives me a huge file almost as big as the source after 1st pass, after 2nd pass the bitrate is fscked, like 300kbps, i can count the macroblocks on one hand. what the hell is going on?
is there an utility that wipes ALL codecs from your HDD, like drivercleaner is for gfx drivers? -
Forget about 2-pass encoding. Just use single pass, Quantization mode. Use a Quantization value around 3.Originally Posted by smoki
ok people, it works...
using xmpeg i was able to do a 3pass 1500kbps encode on a sample 1min mpeg2 capture...the result is awesome. I use a Leadtek winfast 2000 expert (10bit dac, comb filter, etc) with composite inputs (sat box doesnt do svideo over scart)...capturing using Leadtek's own application, WinPVR with the "DVD" preset 720x576@6mbps.
Sometimes i wonder if Winpvr outputs mpeg2 as 100% mpeg compliant material, cos Tmpgenc Dvd Author always complains the GOP is too high...
I'm encoding the 1st video overnight, 3pass overkill but im sleeping anyway
Will let u know how it turned out. Cheers
If you don't need a file of a specific size there's no point in a multipass encode. Quantization mode is a constant quality method. Pick the quality you want, every frame will have that quality. The file will come out to whatever size is needed to maintain that quality with only a single pass.
i am still kind of aiming for 2x700mb for 2 hrs of material. 1st "CD" was done today morning, it looks really good @ 1500kbps. It finally works dammit...Xmpeg foreverOriginally Posted by junkmalle
Glad it knows how to do multipass without those pesky job controls.
* just a quick question on resizing: the material is 16:9 but the card captures it in 4:3 (even if i force 16:9 in the player part). So xmpeg sees it also as 4:3...does resizing mess up the 1:1.25 ratio in the end? (im kinda confused on what valid resolutions i can resize into). -
started a thread on hardware encoding here
https://www.videohelp.com/forum/viewtopic.php?p=1329852#1329852
maybe someone can help
thanks
Best way to reencode mpeg2 to lower bitrate
By justcurious in forum Video ConversionReplies: 3Last Post: 22nd Nov 2011, 17:05 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Minimum Bitrate MPEG2 encoding
By Rob D. in forum ffmpegX general discussionReplies: 4Last Post: 14th Jul 2010, 09:44 -
mpeg2 bitrate conversion
By sandiegoguy in forum MacReplies: 6Last Post: 16th Aug 2009, 03:40 -
Mpeg2 artifacts at ~high bitrate.
By ronkkrop in forum LinuxReplies: 24Last Post: 13th Apr 2008, 15:06
