how can i make menus for a touch screen dvd player?
You have a touch screen DVD player ? Most touch screen setups use some form of contact grid or light grid to determine what has been chosen. Generally, it translates this information to respond so the OS sees the same input as if a mouse button had been clicked there. Therefore, you may not have to do anything special at all, as the system will take care of it for you. You just need to design the menus. If there are special requirements, only the manual will be able to explain them to you.
Read my blog here.
Do you own an electronic device with a touch screen?
By johns0 in forum PollsReplies: 24Last Post: 4th May 2017, 11:36 -
Touch screen monitors or all in one touch screen pc?
By Rudyard in forum ComputerReplies: 4Last Post: 1st Dec 2010, 10:02 -
Touch screen netbook for your Fridge ( with Andriod, Maybe )
By SingSing in forum ComputerReplies: 5Last Post: 11th Aug 2009, 21:45 -
Touch Screen Monitor.
By slimmx in forum ComputerReplies: 1Last Post: 25th May 2008, 09:50 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01
