Hi,
I have an .OGM file and it's audio works just fine, it's in sync and everything with just two different audio tracks and nothing else. Now, I've used the guide to convert OGM to AVI using VirtualDubMod, and it worked great for most of my .OGM files but I am having problems with two files, that everytime I extract the audio from the video and than multiplex the audio and video again, the audio and video are out of sync by like less than or 1 seconds. I know it's not too much, but it still bothers me. Now, I know the problem is not with the OGM file as I have checked the OGM file and the .OGG audio is working just fine (it's in sync and everything). Is there anything I can do to get the audio in sync with the video?
Regards,
diE
LiVe iS juSt EvIl SpElLed BAcKwArDS!
Hi,
The .OGG audio files within .OGM have a "Audio-Video Interleave", in other words delay of like -5. When I extract the file, is that delay gone, or it extracts with that delay? Will I have to re-insert the -5 to get perfect synchronisation?
Regards,
diELiVe iS juSt EvIl SpElLed BAcKwArDS! -
Depends. If you extract or convert with mencoder, then the delay should still be there. VirtualDubMod, I guess not or else your file would be in sync.
Ogm to Avi, pick of audio track, external subs (batch job)
By 45tripp in forum User guidesReplies: 2Last Post: 10th Jun 2009, 16:53 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 16:14 -
converting OGM/MKV to AVI (with dual audio track)
By mwasim1 in forum Video ConversionReplies: 1Last Post: 4th Jan 2009, 22:54 -
How do I convert .ogm file to .avi and keep a certain audio track?
By Moldiver in forum Video ConversionReplies: 7Last Post: 22nd Jul 2007, 08:43 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
