Is anyone aware of a utility that would allow me to manually set the frequency/speed of an AMD Athlon XP-M (Mobile) processor under Windows?
I am using SpeedswitchXP atm, which lets me set fastest/slowest depending on battery/AC/load etc, but since there are a few "steps" in between those fastest/slowest speeds, can I manually set them (or can it be done in Speedswitch?). I am trying to run some older games on my laptop, and running at the full 1800Mhz is uneccessary and only causes the fan to roar like a 747 constantly - the games, being older, run ok at 533Mhz (the slowest) but a little boost wouldn't hurt...
And no, there is no options in the BIOS to do that - it's an eMachines laptop and the BIOS is severely restricted (imo).
Results 1 to 1 of 1
Intel i5 2430M processor or AMD A8-3500M quad-core processor?
By jbitakis in forum ComputerReplies: 5Last Post: 11th Nov 2011, 20:31 -
Spec a HTPC, AMD v INTEL, processor confused.
By Rudyard in forum ComputerReplies: 5Last Post: 23rd Dec 2010, 20:54 -
Choosing motherboard for AMD processor
By Illusionist in forum ComputerReplies: 3Last Post: 11th Jul 2008, 13:58 -
Need specific setting for CloneDVD Mobile.
By g12345567 in forum Portable VideoReplies: 2Last Post: 25th Mar 2008, 17:05 -
amd slot a processor
By black cloud in forum ComputerReplies: 13Last Post: 13th Sep 2007, 08:08
