I have some avi movies and would like to convert them so that Nero can read them and was wondering are there any good free ones that work. Right now I have DivxtoDvd but that takes awhile. My second question is since im having horrible problems trying to figure how to burn using the software I have is it worth it for me to buy nero ultra?
http://members.dodo.net.au/~jimmalenko/AVI2DVD.htm steps you through the process of converting your AVI to a DVD-compliant MPEG-2 file, and there are many other guides just like it in the guides section to your left.
There's also a number of guides dealing with burning woth different sofware - also check out the tools section for other burning tools.
Funnily enough, DivxToDVD is probably the quickest AND best all-in-one I've seen to date ...If in doubt, Google it.
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 19:57 -
Convert AVI and burn to DVD: problem w/ NERO
By jimbo213 in forum Video ConversionReplies: 3Last Post: 3rd Aug 2009, 05:10 -
Can I use NERO 7 to convert AVI to FLV??????
By reez in forum Video ConversionReplies: 5Last Post: 24th Dec 2007, 01:43 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 01:07
