I recently made an svcd from an avi file, but when I play it on my dvd player or windows media player there are a whole bynch of little blurry squares all over the screen making useless to watch. When I watch it on PowerDVD it works fine though.
NTSC SVCD
16x9 aspect ratio
non-interlace
Full screen (keep aspect ratio)
Re-encode it at a higher bit rate - 2250 is the limit for SVCD
Another option is to encode the file at DVD bit rates but at 352x240 size.
Lastly, you can use AviSynth and a Deblocker plugin - DGIndex is very good
LoadPlugin("d:\plugins\DGDecode.dll")
Avisource=("d:\myavifile.avi")
deblock(quant=20)
BlindPP(quant=8, cpu2="xxxxoo", moderate_h=45, moderate_v=55)
ConverttoYV12() -
That should be fine. The specs can be found here:https://www.videohelp.com/svcd
Google is your Friend
Mpcstar pixelation problems picture becomes clumped squares
By kakashi9401 in forum Software PlayingReplies: 0Last Post: 15th Jul 2010, 14:52 -
why do cds or dvds stick or show squares or slow down when playing?
By wan2no in forum Newbie / General discussionsReplies: 12Last Post: 4th Apr 2008, 22:09 -
A font with only squares, how to create?
By sybariten in forum ComputerReplies: 3Last Post: 21st Feb 2008, 16:38 -
Squares Appear When Playing Online Games - Resolved
By HacktheHacker in forum Software PlayingReplies: 6Last Post: 20th Jan 2008, 17:07 -
3d Games Cause Large Squares on Screen - SOLVED!
By HacktheHacker in forum ComputerReplies: 11Last Post: 29th Jun 2007, 20:59
