Hi
I have an NTSC video that I want to transfer to DVD,
If I get an NTSC video capture card for my PC does anyone think that I should be able to use my UK origin VHS player to play the video and capture the image on my pc ?
Can anyone recomend any good capture cards ?
cheers
G![]()
All you need is a good capture card and an NTSC playback VCR.
The card will make the conversion.
I'm about to do the reverse which is a PAL VHS into a PAL VCR outputing to my ATI AIW set to capture in PAL format which in turn produce a PAL picture on my PC monitor. From there I can make the conversion to NTSC for playback on our DVD player(s)Project Digital: Eliminate All Physical Media is finally underway! -
Oh -
I'm not sure what card you would need. My AIW is a tuner card so it has the ability to make the conversion because its designed to playback different formats.Project Digital: Eliminate All Physical Media is finally underway! -
Hi
thanks for your thoughts, think I'll try a tuner card as you say
cheers
G -
Most PAL vcr''s with NTSC playback will put out a PAL60 signal.
Not all capture/tuner cards can accept that signal. -
Which software would you use to select and capture PAL source? i tried virtualdub and others and they all have the same 2 ntsc sources and 15 pal sources but all 15 pal sources dont work.
how do you select/tell the program that the source is PAL at 60hz.
I have ATI AiW Radeon 7500. would that have PAL 60hz compatabillity? ati website doesnt say anything about that under aiw7500 description.
I think that my problem is that the PAL-VCR with ntsc playback outputs a PAL60 signal (if what you said above is true and relevant to my sitation) and there's no way to change it in the VCR.
Also I have a PAL->NTSC standalone converter that is stupid and requires a 50hz compatible ntsc tv to display properly in ntsc. If it also requires a PAL50 signal input then I am also out of luck. If that's not the problem then...
I can't find a sofware/setting where i can SELECT PAL at 50hz or 60hz as the input .
please help -
In the TV Setup, under the Video tab, there Broadcast Standard Pull-Down, PAL60 is listed there (last PAL standard).
I'm using MMC 9.08
But I think all the MMC's have that settingProject Digital: Eliminate All Physical Media is finally underway!
EP VHS video capture
By Lucky Starr in forum Capturing and VCRReplies: 11Last Post: 27th May 2011, 00:09 -
How to capture NTSC video from PAL VCR player
By Cyberrock in forum Capturing and VCRReplies: 0Last Post: 28th Sep 2010, 03:36 -
Trying to capture video from VHS
By JoshGlzBrk in forum Capturing and VCRReplies: 1Last Post: 19th Dec 2009, 21:33 -
Trying To Capture NTSC VHS Video With UK Equipment
By pbar in forum Capturing and VCRReplies: 37Last Post: 21st Jul 2009, 09:59 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 19:42
