Hi when i try to open a avi file in Adobe Encore it seys the it worng resulotion 4 this projeckt,,, where to i chance the res'?
You can only change the resolution by either re-encoding, or patching the header using something like DVD Patcher (which may only accept MPEG files ???). what is the res of the AVI file you're feeding it ?
If in doubt, Google it. -
AFAIK Adobe Encore is authoring software, so you may have to convert your AVI to DVD-compliant MPEG first with something else (I haven't used the software, but by looking at the blurb in the Tools section, it doesn't convert AND author, so please forgive if I'm wrong on this).
DVDSubEdit... Everything Is Wrong!!!
By Typhoon859 in forum SubtitleReplies: 18Last Post: 5th May 2009, 09:08 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 10:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 19:17 -
What is wrong with this picture?
By anonjon in forum RestorationReplies: 20Last Post: 10th Sep 2007, 14:02 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 05:11
