converted file to nero to play on dvd or tv. can I reverse it to avi ?
If you don't have the original file, you can convert the DVD to AVI by looking to the left for "Convert' and find 'DVD to AVI'. It depends on what type of AVI you want to convert to. You will lose quality. If you want to go to XVID or DIVX, you might look at FairUse Wizard as it's easy and quick.
Reversing Color Filtering Effect
By Michelle76 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Apr 2012, 12:23 -
Reversing PAL speedup.
By rcavanah in forum EditingReplies: 3Last Post: 22nd Sep 2011, 14:26 -
Reversing a fade to black
By dave_van_damme in forum EditingReplies: 10Last Post: 12th Mar 2009, 22:15 -
DVD -> AVI -- reversing time compression (pref. wth VirtualDub)
By Calidore in forum Newbie / General discussionsReplies: 0Last Post: 20th Oct 2008, 15:22 -
Reversing Clips - VideoStudio
By markannab in forum EditingReplies: 1Last Post: 15th May 2007, 22:35
