i just downloaded cucusoft avi to vcd dvd version 6.11 and when i convert an avi file to svcd it nearly triples the file size (that's only at a medium quality setting too). i was using v 4.02 and that didn't even double the file size and the quaility was ok. is there something wrong with v 6.11 or do i have to use 4 discs to watch a good quality movie?
SVCD video rate is somewhat variable up to 2600 kbit/sec MPEG-2 (30-35min per CDR) Lower bitrates might double the time.
https://www.videohelp.com/svcd -
so what are you saying. as long as the bitrate is below ~ 2000 kbit/sec the converted svcd file won't be so big?
Originally Posted by duffski
ya i know that, i'm looking to get the best quality on to 2 discs. does it matter what software i use to convert the avi to svcd?
Depends on the quality of the MPeg2 encoder at low bitrates. I usually don't go much below 2600 so I'll let others comment.
I used to drop down to about 2000Kbps to fit 44 min TV shows to a SVCD, but that was long ago. DVD is so cheap now.
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 1st Aug 2007, 23:41 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
