Results 1 to 11 of 11
  1. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    I have a WAV file 6 channel that I need converting to either MP3 or WMA. Ive done a serach in this forum and googled from the answer, but all the tools ive come across with convert to stereo.
    I need to convert to MP3/WMA but also retain the 6 channels, not downmix to 2 channels.
    Im not sure if this is possible with MP3, but I do know its possible with WMA.
    Is there any tool that allows me to convert WAV 6 channel to MP3 or WMA 6 channel.
    Thanks.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hi,
    http://fileforum.betanews.com/detail/MP3_Surround_Evaluation_Software/1102032674/1
    I did a yahoo search for "6 channel mp3" and found this link.
    Should help.
    Kevin
  3. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Thanks Kevin for the info.
    But that software is only capable of playing surround MP3, not converting them to surround. I tried to convert to MP3, but it downmixes to 2 channels (stereo).
  4. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Anyone?
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Sounds cool - what player capable of playing sorround MP3/WMA do you have?
    /Mats
  6. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Well, im just doing some experimenting with car systems that are capable of playing mp3/wma.
  7. Member corrax's Avatar
    Dec 2003
    Maryland, USA
    That Fraunhofer software also includes an encoder. Here is a direct link to their site if you need more information:
    http://www.iis.fraunhofer.de/amm/download/mp3surround/index.html
  8. Member corrax's Avatar
    Dec 2003
    Maryland, USA
    Just to clarify, I tested this with a sample 6-channel WAV available on their site.
    1. Converted it to MP3 using their encoder. Windows thought it was 2-channel stereo.
    2. Played the file in their surround player. The software told me the file was 5.1 surround.
    3. Played an MP3 that I know to be 2-channel in their software. It told me that the file was stereo, not surround.
  9. Member Cornucopia's Avatar
    Yes, it should be using MPEG2.5 Layer 3 (Backward Compatible) spec, which means it encodes MPEG1 Layer3 in stereo like normal, and then appends the surround chunks. Non-surround players just ignore the surround channels and plays the "fallback" chunks. Since it doesn't know any better, it assumes it is stereo.
    Incidentally, it duplicates the front L, R channels in the surrounds for compatibility sake, but this comes at a cost of compression bloat, and there is some discrepancy between a correctly downmixed 2 channel file and an automatically downmixed version of a surround file--that's why the MPEG people came up with the idea of the "Non-Backward Compatible" (aka AAC). This applies to Layer 2 as well as Layer 3.
    Also, there is no "Surround" flag in 2-channel MPEG audio (unlike Dolby Digital), so if it sees just 2 channels, it should read stereo and not surround.
  10. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Its works only with Fraunhofer software, all the other software players like media player classic, powerdvd, wmp etc.. recognises the mp3 as stereo.
    Thanks for all your help guys.
  11. Member Cornucopia's Avatar
    Think of it like Color and Black&White broadcasting.
    Black&White receivers/monitors will show B/W even with color signal, as the signal is formatted such that it gives a backward-compatible B/W signal + the supplemental color subcarrier info, the color part being ignored by B/W monitor.
    Color monitors & receivers will show Color programs as color, but they will also show B/W programs as plain B/W. It can't "automatically create" color where there is none. There is no Color supplement.
    99.999% of mp3 players out there (incl. WMP, etc) are 2ChannelMp3-aware only. It's possible that the Maven softwares read it as fully surround, but I've had difficulty getting it to work.
