i burnt an svcd to a cd and it plays on my dvd player. the only problem is that the film freezes for a split second every 2 seconds. it's barely noticable, but i do get kinda seasick watching it. what did i do wrong? did i burn it at to fast a speed? or was the problem caused when i converted the avi to an svcd? thanks
Hi,
Try a different brand cdr first. It could be bad media. Then if that doesn't work cut out a short clip from the avi and reencode it. If you get the same problem then it may be the encoding process. What program are you using to encode the avi??? Are you using the default svcd settings?
I played the original svcd on my computer and the split second freeze thing happened. so it must be the programme that i used to convert the avi to an svcd. the software is cucusoft avi to vcd dvd converter. i'm using the default settings. should i try get different software or can it be fixed?
maximizing picture quality
By thekenoshakid in forum Newbie / General discussionsReplies: 24Last Post: 21st Sep 2022, 21:38 -
Poor Picture quality - need help!
By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 12:00 -
Youtube picture quality
By Juc1 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jan 2009, 20:36 -
picture quality in after effects
By wan2no in forum EditingReplies: 1Last Post: 29th Nov 2008, 04:47 -
picture quality
By nexous in forum RestorationReplies: 4Last Post: 18th May 2007, 04:03
