Hi mate,
I am trying to burn DVD files but I kept failing at the same part. I dont know wot else to do. THe file came originally with 2 avi. Then I transcoded it seperately. Then I use shrink to join it. THen I try to burn... the result is 6 wasted good DVD. PLease help... I enclose herewith my log file.
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 28/05/2003 6:53:46 PM
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 22/07/2004 5:33:44 PM
Nero version: 6.3.1.19
Recorder: <SONY DVD RW DRU-710A> Version: BY02 - HA 1 TA 1 - 6.3.1.19
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <SAMSUNG CD-R/RW SW-212B >Version: BS07 - HA 1 TA 0 - 6.3.1.19
=== Scsi-Device-Map ===
DiskPeripheral : ST340014A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : SAMSUNG CD-R/RW SW-212B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : SONY DVD RW DRU-710A atapi Port 1 ID 1 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a xmasscsi Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
SAMSUNG CD-R/RW SW-212B D: CDRom0
SONY DVD RW DRU-710A E: CDRom1
AXV CD/DVD-ROM F: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 767MB (785904kB)
Free physical memory: 388MB (397372kB)
Memory in use : 49 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
25.6.2005
UDF/ISO compilation
10:59:28 PM #1 Phase 112 File dlgbrnst.cpp, Line 1865
DVD-Video files reallocation started
10:59:28 PM #2 Phase 114 File dlgbrnst.cpp, Line 1865
DVD-Video files reallocation completed (no file modified)
10:59:28 PM #3 Text 0 File Isodoc.cpp, Line 6065
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
10:59:29 PM #4 Phase 111 File dlgbrnst.cpp, Line 1865
DVD-Video files sorted
10:59:29 PM #5 Text 0 File Reader.cpp, Line 118
Reader running
10:59:29 PM #6 Text 0 File Writer.cpp, Line 124
Writer SONY DVD RW DRU-710A running
10:59:29 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
10:59:29 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3899
10:59:29 PM #9 Text 0 File Burncd.cpp, Line 3173
Turn on Disc-at-once, using DVD media
10:59:29 PM #10 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2286111 (508:01.36, 4465MB)
10:59:29 PM #11 Text 0 File DlgWaitCD.cpp, Line 259
Write in overburning mode: NO (enabled: CD)
10:59:29 PM #12 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: SONY DVD RW DRU-710A, Media type: DVD-R
Disc Manufacturer: TTG02 -
Disc Application Code: 64, Disc Physical Code: 193
10:59:29 PM #13 Text 0 File DlgWaitCD.cpp, Line 420
>>> Protocol of DlgWaitCD activities: <<<
10:59:29 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286112 (2286112) = #2286112/508:1.37
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286112 blocks [SONY DVD RW DRU-710A ]
10:59:29 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [SONY DVD RW DRU-710A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681957376, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286112 | lead-out | 1 | 0x00 | 0x41
10:59:29 PM #16 Phase 24 File dlgbrnst.cpp, Line 1865
Caching of files started
10:59:29 PM #17 Text 0 File Burncd.cpp, Line 4183
Cache writing successful.
10:59:29 PM #18 Phase 25 File dlgbrnst.cpp, Line 1865
Caching of files completed
10:59:29 PM #19 Phase 36 File dlgbrnst.cpp, Line 1865
Burn process started at 4x (5,540 KB/s)
10:59:29 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:59:29 PM #21 Text 0 File dlgbrnst.cpp, Line 1723
Set remaining time: 14:10,273 (850273ms) -> OK
10:59:29 PM #22 Text 0 File DVDR.cpp, Line 1932
Recording mode: Sequential Recording Mode
10:59:29 PM #23 Text 0 File Mmc.cpp, Line 20464
Set BUFE: Power-Burn -> ON , Generic write control : ON
10:59:29 PM #24 Text 0 File DVDR.cpp, Line 2073
Start write address at LBA 0
DVD high compatibility mode: Yes
10:59:29 PM #25 Text 0 File Cdrdrv.cpp, Line 8128
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
10:59:51 PM #26 Text 0 File Cdrdrv.cpp, Line 1294
22:59:51.000 - SONY DVD RW DRU-710A\H1 T1 : Queue again later
11:13:14 PM #27 SCSI -1135 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03AC0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x11 0x9A 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
11:13:14 PM #28 CDR -1135 File Writer.cpp, Line 304
Write error
11:13:14 PM #29 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
11:13:14 PM #30 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
11:13:14 PM #31 Text 0 File DVDR.cpp, Line 2315
EndDAO: Last written address was 1153727
11:13:14 PM #32 Text 0 File dlgbrnst.cpp, Line 1723
Set remaining time: 0:00,000 (0ms) -> OK
11:13:14 PM #33 Text 0 File dlgbrnst.cpp, Line 1723
11:13:14 PM #34 Phase 38 File dlgbrnst.cpp, Line 1865
Burn process failed at 4x (5,540 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 28/05/2003 6:53:46 PM
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28/10/2003 8:02:00 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 4/08/2004 3:59:42 PM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 11 of 11
Three possible things to try
1) Your media might be bad. Try burning at 2x
2) I see you have Aspi in your Windows drivers, AND WNaspi for Nero. They might be bumping into each other. If you can uninstall Adaptec's ASPI and just keep WNaspi, it might work better.
3) Update your Nero software to the latest revision of your software and try again. -
Thanks Soopa,
More questions.
I tried other movie that I downloaded, the same case, eventho it is working well & wacthable on my computer right to the end.
I wonder how can a bad media source screw up a burning process whilst the simulation is perfectly fine?
2ndly, they are all being burnt just fine before this? could it because I use different type of blank DVD-R (compatible)? All this has the same setup in terms or drivers etc.
And more info to you, when I look at the back of the failed burnt discs, they all have different burnt marks, eventhough their have the same type of failure (in my log).
Please help. It is such a good quality movie & so much effort to get it.
cheers
k -
I made about 7 coasters in a row and was completly lost and frustrated. I noticed though, I had "burn at once" checked at the end of the nero recording process and once I unchecked it I have been error free. I am not sure if it will work for you but I was amazed that even the smallest details can make a world of difference.
Try unchecking disk at once at menu screen prior to burning your dvd-video.
good luck -
hi tec,
My Nero is 6 for Sony ver. I have look at your suggestion but the "disc at once" is shaded or not availble for me to alter. It is at "disc at once". I have also tried different speed to min to max. Still the same. I am suspecting the Burner has physical fault.
k -
Looking at the log > the DMA setting for your drives seems to be switched off.
Should be activated of course. -
Hi deckard,
Ok I changed my DMA to ON. But still failed at actual burning but ok in sim.
here is part of the log that shows the changes
DiskPeripheral : ST340014A atapi Port 0 ID 0 DMA: Off
CdRomPeripheral : SONY DVD RW DRU-710A atapi Port 1 ID 1 DMA: On
SAMSUNG CD-R/RW SW-212B D: CDRom7
SONY DVD RW DRU-710A E: CDRom8
AXV CD/DVD-ROM F: CDRom2 -
Have you had any success with this batch of DVD-r media when you burned another movie previously?
Why not try burning it on a DVD-rw first? -
Hi inuyasha,
Yes I did ONCE & THE FIRST of the batch it was successful then disaster until the 12th disc, before I used cheap princo all work fine at 4x, the max speed for the DVD-R disc. Then I finished that I used TDK at all different speeds, 4x-8x, still not working... WRITE ERROR... arrghghgghg.,,, HELP!!!!
cheers
k -
Hi,
My problem is now solved. Wot I did is updated my Nero to 6.6, from 6.3 AND swicth on all my IDE channel. For those who dont know how to do it, goto control panel > system > hardware > click device manager > IDE ATA/ATAPI > turn on DMA from here. Then run sim on Nero to save from wasting discs, once completed, save a log files so you can be sure if all the DMA is on. If not you need to goto the driver tabe in IDE ATA/ATAPI part to uninstall then reboot & the computer will self reinstall the driver, repeat the process until you see in your log all the DMA is on.
cheers
k
8gb dvd burning failed
By renz_007 in forum Newbie / General discussionsReplies: 8Last Post: 8th Apr 2011, 10:08 -
No audio when burning dvd using AVStoDVD (log posted)
By aikipaul in forum Authoring (DVD)Replies: 4Last Post: 4th Oct 2010, 12:15 -
nero burning failed
By KristijanR in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2009, 02:10 -
[Help - Log inside] Having issues burning on Dell M1330 with Vista using
By dellfanboy in forum Newbie / General discussionsReplies: 2Last Post: 23rd Feb 2008, 21:14 -
Nero failed burning DVD
By DuBsTaR in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2008, 15:15
