Hi,
I ripped a DVD which had a bad scratch on it, I was forced to 'ignore read errors' having tried ripping with 2 different DVD burners -- there were a few hundred read errors in total. This has effected about 20 seconds of a 2 hour film. No big deal. Playing on my PC I get a few pixelizations and a bit of sound distortion for the 20 seconds. But on my standalone player and my TV when I get to the problem area, the DVD freezes and I can't even fast-fwd thru the bad area, I'll be forced to go back to the start and enter a specific time --that being just after the problem area-- to get passed it. Is there some software that can clean this up a bit to help me get thru the problem area without actually editing it out?
Any advice will be greatly appreciated.
Many thanks.
No need to rip to MPEG2. Why not just load the DVD into TMPGEnc DVDAuthor and use that to cut out the bad section and reauthor.Originally Posted by Soopafresh
Thanks guys, but as I wrote in my post I'm looking for a solution that does not involve editing the bad section out, it's partially watchable can't the streams be somehow 'normalized' so that while not adding unknown bits, the bits are accepted by my standalone DVD player as 'valid' values in the stream and the DVD doesn't freeze? Or should I just edit out the few seconds around where it actually freezes?
Cheers. -
try ripping the scratched dvd with a different pc. sounds like your pc dvdrom/dvdrw isn't capable of reading scratched discs. you could try ripping with VOBBLANKER.
Lots of pixelization on capture
By sum_guy in forum Capturing and VCRReplies: 2Last Post: 24th Feb 2011, 21:01 -
IsoBuster settings for read errors
By 1337assassin in forum Newbie / General discussionsReplies: 8Last Post: 23rd Oct 2010, 12:20 -
How to Convert VOB file from DVD with ignore read errors
By designbuyers in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 09:17 -
Is it possible to overcome read errors in homemade DVD?
By geepondy in forum DVD RippingReplies: 8Last Post: 19th Jun 2007, 22:21 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
