whats the easiest way to combine 2 avi files without burning them to cd?
VirtualDub. File-> Append avi segment.
Put everything in Direct stream mode, Select as avi.
This will concatenate both avi's. -
yep, in the guides section (<< to your left), there's even a whole section devoted to How to cut/join/edit AVI/DivX/XviD, and from within that, there's a guide called How to easily join AVI files with VirtualDub, or there's another one called How to Cut/Join with Virtualdub
If in doubt, Google it.
Join or Combine 2 AVI files with no quality loss.
By deadnuttz in forum EditingReplies: 18Last Post: 21st Sep 2016, 02:09 -
How would I combine 2 avi files into one?
By Variable in forum Newbie / General discussionsReplies: 7Last Post: 27th Sep 2010, 16:50 -
Combine/Merge two avi files
By motherwell in forum MacReplies: 4Last Post: 28th Jan 2010, 15:45 -
vdub virtualdub can I combine several small avi files into one
By case310350 in forum EditingReplies: 2Last Post: 5th Jan 2009, 02:23 -
trying to combine quicktime files
By dwayne00 in forum Newbie / General discussionsReplies: 3Last Post: 4th Apr 2008, 19:09
