Recently I been unable to burn onto Laser DVD+R. I get the this error when using DVD Decryter:
I/O Error!
Device: [1:0:0] LITE-ON DVDRW SOHO-8325 VSV0B (D:) (ATA)
ScsiStatus: 0x02
Interpretation: Check Condition
CDB: 28 00 00 1B 58 C0 00 00 01 00
Interpretation: Read (10) - sector: 1792192
Sense Area: 70 00 03 00 00 00 00 0A 00 00 00 11 00 00 00 00
Interpretation: Unrecovered Read Error
I've tried Nero but it still has the same problem. I've tried it with a Verbatim DVD-RW disc and had no problems. How could i fix this
You state that you have had no problems with Verbatim DVD-RW so to me this suggests your drive doesn't like the +R discs you are using.
Is your writer capable of writing to DVD+R ?
Try updating the writers firmware as this can increase the amount of different media it can use.
Try a different disc and see what happens.
Have you successfully written to +R with this drive before ? -
I found the problem, i went on the Lite-on website and found this
Quote:
Recently, there have been a lot of users who failed to burn disk after upgrade Windows XP from SP1 to SP2, which is due to the upgrade of Windows XP SP2 caused the compatibility problem with the burning software. If the NERO burning software that came with the burner (CD-RW, COMBO, or DVD RW drives), version lower than 6.3.1.20, please update to the latest version available at NERO official website. For further information, please refer to http://www.nero.com/en/632011181528025.html
I had this problem, downloading nero fixed it. -
How could upgrading Nero solve a DVDDecrypter write error? (OTOH, the error message indicates a read error?!?)
/Mats
DVD burning problems with new discs
By Lensmeister in forum Authoring (DVD)Replies: 10Last Post: 9th Jan 2011, 10:19 -
Burning multiple remuxed folders to discs, playable as dvd
By blue2 in forum Authoring (DVD)Replies: 6Last Post: 8th Oct 2009, 09:05 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 13:36 -
Burning videos from camcorder to DVD discs with time stamp. Please help!!!
By csh in forum Authoring (DVD)Replies: 2Last Post: 29th May 2009, 10:38 -
Laser Etching DVDR That are NOT Light Scribe Discs.
By Scooter_NJ in forum Authoring (DVD)Replies: 4Last Post: 17th Nov 2008, 18:11
