Hi,
First off, I'm completly new to encoding avi's to DVD, so please be specific in anything you recommend.
I'm trying to convert avi files to the DVD format and then burn them onto a DVD to play them in my DVD player.
I tried using Avi2Dvd, and it converted and played without any problems, but the video was much too dark on the TV, even though the avi file's brightness was just fine when I played it on my computer.
Is there a good, free program that I can use to adjust the brightness of the video while it is being encoded to the DVD format? This as opposed to encoding it with VirtualDub or something first and then re-encoding it to DVD format. Basically, something that will do it all in one step rather than two (and take up less hard drive space in the process).
Thanks for any suggestions.
You can still use VirtualDub for the adjustments and frameserve to your encoder. This eliminates the in-between file. Go to the 'Guides' section to the left <<< for information on frameserving with VirtualDub. If you are using TMPGEnc encoder to convert to DVD, it also has a brightness adjustment.
You also might want to try VSO DivxToDVD. It converts AVI and other formats to DVD, it's freeware, easy to use and does a good job, though I don't believe it can adjust brightness.
Correcting saturation, contrast, brightness, etc...
By takearushfan in forum RestorationReplies: 28Last Post: 21st Sep 2011, 23:32 -
How do I increase brightness/contrast on DVDR only have DVD to work with)
By sonicdeth in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2010, 12:44 -
Video editing of brightness and contrast?
By capman21 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 6th Feb 2008, 19:31 -
Change brightness, contrast, color, etc.
By JoeMuskie in forum EditingReplies: 4Last Post: 22nd Oct 2007, 23:26 -
Fixing brightness/contrast on a DVD
By Salva Veritate in forum EditingReplies: 4Last Post: 7th Oct 2007, 21:05
